satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
Here is the complete device list Peon has as TBS 5925 was unplugged in the previous one. Can`t edit it, so here it is again!
Looks like it will with the addition of an internal fan :)
A fan does not mean it runs a lot cooler, just the heat generated is spread out elsewhere
s-band
Essex
@satosk How do you rate the NJR2842 compared to something like the SMW equivalent 0.8dB PLL?
satosk
First tests that Peon made today.
Close frequencies at 30W (11640-11655 MHz).
StreamReader 1.2.3.1396 was used for all tested cards.
TBS 6522 wasn`t tested as it doesn`t support hw blindscan.
TBS 5927 at 30W.jpg TBS 6983 at 30W.jpg TBS 6903 at 30W.jpg TBS 5925 at 30W.jpg Prof 7301 at 30W.jpg
satosk
Low SR test at 23E (12600-12660 MHz).
TBS 5927 at 23E.jpg TBS 6983 at 23E.jpg TBS 6903 at 23E.jpg TBS 5925 at 23E.jpg Prof 7301 at 23E.jpg
satosk
We have several PLLs, but they are all single band only, no fullband as the NJR one. I like SMW, too as I have 3 WDL DRO type "E" LNBs, but instead of "another" Ku band I have invested in 2 full pro grade X band units (feedhorn, 2x omt, 2x polarizer, 4 x Norsat X1000HAF lnbs).
So can`t compare to anything atm..
What Peon can say to this is the fact that when he compared NJR 2842 to 2843 he always got the same frequency. At this point it`s worthy to say, that the TBS 5925 gives the most precise frequency reading from all available cards and Peon uses it as his reference one.
Another test to lock signal with low symbol rates is at 10°East, where we have a lot of radio stations with 256 Ks at a distance of only a few khz.If more was needed,and this time Tuner 5927 rises to the level of other tbs card from the top:
dino123
openbox sx6
europe
Where is driver for download to work with EBSpro on Windows 7?
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Ireland
Please tell me where I can buy it as cheaply as possible?
satosk
Official windows driver for TBS5927, v1.0.0.3 was released on Monday 28 November and can be downloaded here: TBS TV Tuner USB
TJExcalibur
Out of this world.
Southern England
Here is my own experience with tbs5927 usb.Unfortunately I do not know how it could post the whole text on the forum, that's why I compressed it.
I hope to help those who seek such a device for satellite reception.
  • tbs5927 .pdf
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Is the 5927 much faster than the 5925 for blindscan ? Is the 6903 even faster than the 5927 btw ?
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
5927 faster in BLScan2 mode.
6903 and 5927 use same tuner/demod STV6120/STV0910AD - so blindscan performance ~equal
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Yes but is it much faster than my 5925 in non BLScan2 mode ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
No one can answer me ?!
@Crazyscan answered your question very well.Maybe only one example can convince you,that tbs5927 does a blindscan faster than tbs5925 at the same number of steps,of 3.0MHz.From this point of view it is the best in the category of USB devices.There are other features that make it better than 5925!
Look at the two spectrums with both devices:
SnelleJef
Triax 88 Inverto Black Ultra Lnb And The VU+ Zero 4K
Belgium
Hello satesco i have read for a few days on what usb card to buy is the 5927 still the best usb card to buy now? i want to monitor only signals to see if it's worth to upgrade my dish so it needs to be a very sensititve card also do they come close to a vu+ zero 4K or octagon sf8008 for example in sensitivity my budget is 250 euro wich is exactly the price of this card + shipping if there is something realy good i can up the budget to 500 euro i have read the pdf from you with many thanks still learning about sat cards and i will continue to read thanks in advance
Hi SnelleJef,
Thank you for your trust,but I confess that I'm put in a messed-up situation,to recommend a product on other people's money.And I don't want to make a mistake at other people's expense,in this case,yours.
I also have to add that I do not know the sensitivity of the two receivers mentioned by you(Vu+ & Octagon),because I have never tried them.The only thing I can say with certainty without mistake that the tuner of 5927 is the most sensitive to weak signal as that of the 6983 or 6903.It's actually in the same performance class as the last two,and besides,has full crazyscan support.
From this point of view and with dvb applications 5927 can be used for many things,i.e.signal checking and monitoring, MIS reception, antenna installation,reception of special parameters, etc.But you should know that it does not read and lock the transponders with the S2x extension!You must take this into account if you want to compare it with,for example,Vu+ or Octagon.
I ran an IQmonitor test at 27.5W and,as you can see,the app can scan like 6983 or 6903.
Regards
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
Hello SnelleJef
The vuzero4k's tuner is good, but it has a driver problem. The signal levels it displays are not actual. It is a problem that
should put solution vu+ and that they do not.
TBS 5927 is more sensitive.
