Loss of supertennis
Digiscan
Gigablue Quad Plus with 90cm alloy dish (motorised)
HP Pavilion pc 8gb ram 2tb HDD using windows 10
Essex Coast
Hi fellow members.
I wonder if a member could enlighten me on how I will now receive the above which on Sept 1st changed frequency on Hotbird from 12476Mhz to 12616Mhz (forming two channels it appears).
Kingofsat lists these channels as clear.
I would appreciate a members response please.
S
Sleepingwiththefish
I also tried 12616 as well a couple days ago, then realized it was gone.
I will miss this one.
Is the one on 9E set to encrypt? Not sure if I can get that Italy beam over here.
Is it still on Tivusat?
Digiscan
Essex Coast
Super Tennis no longer broadcasts FTA from 13 east
Hot Bird 13C (13.0°E) - All transmissions - frequencies - KingOfSat this entry may have been accurate when posted on the 1st of Sept but the channel is no longer there.
Thank you for your prompt reply, I will miss this channel as I watched this 80% of my TV viewing time & it was my chosen channel at switch on.
Kind regards
Digiscan
Essex Coast
Many thanks for your reply.
I like yourself will really miss this channel & it has been my favourite for about 10yrs now .
80% of my TV viewing was Supertennis.
Kind regards
The Supertennis site only mentions Sky & 'free of charge' terrestrial, so would not expect the 9e signal to encrypt, if you able to receive it.
Digiscan
Essex Coast
Digiscan
Essex Coast
Thanks for your interest.
Kind regards
Laser
Gone from CH 30 Tivusat. Just says service not available.
FreesatfromSky
Freesat [Humax HDR 1000S]
Fta(9E/13E/19E/28E) [Fixed Triax TD88]
1.1M motorised satellite dish [unbranded]
What a shame.
ac1139
120 cm PF, 180 cm offset.
100 km north of Vienna
There is a chance on 9°E. There is multistream (MIS), but You need a receiver which can handle MIS and big dish if You are long distance from Italy. Italian beam is very focused on Italy: FlySat Eutelsat 9B @ 9° East Beams
If You are in UK, probably without a chance.
Discussion about Italian Beam:
Many of the 9E Italian beam frequencies are reused on the Nordic beam so the chances of getting the Italian beam in the UK is very remote where frequency reuse is being used.
