Spiff
- May 28, 2015
- Age
- 78
- Location
- Mullion Cove Cornwall
- Website
- shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good evening Gentleman I wonder if this problem is common ?
Loosing channels on a Technomate TM5402 SW Version 1.38P
I have had the receiver for few weeks, I had the same problem once before, no idea how I cleared it that time.
Switched on today it was on Samara TV Nilesat which is a weak one, normal signal level.
Tried other channels of which only a few worked at normal signal levels.
Tried other satellites, nothing, some had the odd channels working.
Changed to the other output on the LNB no chance.
Tried a Viper 4k on the other LNB output to scan one of the sats that did not work, all OK.
Checked all leads, but it would have affected Samara on Nilesat if there had been a problem.
All headings correct on dish as I have cameras on scales to check the settings.
Did a factory reset re-set and loaded the channels from the saved file on the hard drive, no difference.
Unplugged the unit re connected the old Technomate MK1 all ok.
Reconnected the MK3 all ok.
Next time it happens I will try turning the power off.
God Bless Spiff
God Bless Spiff
