Just Sharing This Bulgariasat-1 @ 1.9° east
Might be worth swinging my 5W lnb round onto that one then - 5W is a waste of time here now
Good reception will be possible at your location with an 80 cm dish.
FreesatfromSky
Freesat [Humax HDR 1000S]
Fta(9E/13E/19E/28E) [Fixed Triax TD88]
1.1M motorised satellite dish [unbranded]
Is it temporary or permanent,do we know?
We do not have privy to the broadcaster intentions as nothing is static in satellite broadcasting just enjoy what is free atm.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Let's hope the channels BNT4 HD, Evrocom HD and Kanal3 HD will stay FTA on 1.9°E.
On the other satellites these FTA channels are SD.
MCelliotG
Thessaloniki, Greece
Also The Voice, Balkanika, Planeta and the rest of music channels.
Fisty McB
See my signature...
County Tyrone, N. Ireland
Is anyone else in Ireland or the UK finding reception of this satellite a bit of a struggle? I was using an old Sky Zone 2 dish yesterday and I could only pick up two transponders from this position, only one of which has FTA broadcasts on it (12456 H). Indeed it also seemed extraordinarily "touchy" in that the slightest movement of the dish from the focus cut everything off, something more reminiscent of the mid-powered satellites like Eutelsat 36B or 10A for this dish size - even Eutelsat 3B next door seemed a touch more powerful. The footprint has myself lying on the edge of the 50dbW contour and the transmission parameters (8PSK with 2/3 FEC) don't suggest needing a quite high SNR level to decode, so I'm wondering if the footprint is weak out my direction or are some of the transponders actually on the Balkan beam rather than the European beam?
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Got Voice HD&Magic here on a triax 64cm with a new Inverto LTE filter lnb.
RTP and 1Channel Russia are FTA also on 1.9e
LeBelge
Belguim
..., so I'm wondering if the footprint is weak out my direction or are some of the transponders actually on the Balkan beam rather than the European beam?
Yes, the footprint is weak.
On a Bulgarian forum some people complain about the same problem.
Here in Belgium every thin is fine.
Sat01Uk
SX88 4K
Penta 85cm
Technomate 2600 H2H
Black Inverto LNB
53E - 34.5W
East Anglia
I wish they would make Magic HD like the others on there, maybe showing my age a bit ha, but they seem to play a really good mix of songs that I didn’t hear for ages, and they swap them round too... best thing is you don’t get all the annoying adverts like most other UK versions. I think that channel is under rated.
