Zgemma Receivers
namracyor
8 Satellite receivers, Echostar AD 3600 IP solely used as the dish mover. Technamate TM 6900 Combo, Amiko Alien 2 Spark Triplex, Edision Piccollo s2-T2/C, Technomate TM 8000 Combo, Amiko-X-Finder 2, Octagon SF 8008 +4K, ab Cryptobox 752HD. 1.2 metre Channel Master dish with a twin Invert Tech .2db LNB. 2 computer set up consisting of 2 HP Desktops. Multiple switching units and HDMI splitters.
Near Dorking
As I discovered the Zgemma H7S, and I believe it is the sane for the H9S are not designed for blind scan as I discovered. The H7S will attempt to blind scan when using OpenVIX software, but it only finds about 25% of a satellites activities.
frankviana
Satellites/tv
Brazil
Zgemma-star need fix blindscan driver for h9 devices. I have h9s and h9win.
Manikm909
Small'ish Dish Man
Kent, UK
same opinion here
According to another poster on GitHub, the H9S has no blindscan issue when running OpenATV 6.2.
Manikm909
Small'ish Dish Man
Kent, UK
Doubt the plugin in that image is any different to openvix . The thing is, Blindscan does appear to work on some sats. It is the western sats it cannot do. Which is what i don't understand . It was the same with the H7S
Why not try it ?
