3D files : channel Master feedhorn adapteur
zorrin
Specialised contributor
France
www.facebook.com
france
Here you will find the 3d plan and 3d print file of the Channel Master feedhorn adapter.
  • CHANNEL MASTER FEEDHORN ADAPTER 3D.rar
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
how much you charge zorin?
There are many people on eBay offering 3D printing services such as:
I have not used them but has to be worth getting a quote using the file zorrin kindly shared. I think ABS is the correct material.
zorrin
France
www.facebook.com
france
The problem with ABS is the shrinkage of the material, a material with fiberglass inside will be better I think.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
There is my version of the adapter. It allows fine-tuning (closer/further from the dish) the position of the LNB/feedhorn, it has ~45 mm freedom of movement.
Interesting, you would be the right person to ask if you have identified an issue with the 1.2/1.8m focal point and feed as per the original specifications from Channel Master.
