I've currently got a Triax TD110 ground mounted at the end of my garden but it's a few years old now, the rim has been slightly bent and the arm needs some packers to optimise the signal. I want a completely fresh install in a new location. I need to decide which dish to go for, a lot of the posts on 1m dishes are years old now. I'm aware that the TD110 is no longer in production but might still be able to source a new one. I understand it will outperform the Gibertini 1m if perfectly aligned as it's bigger but getting it perfectly aligned is tricky with the bracket. I was researching other options and came across
Orbital 1m - Gain higher than TD110 specs but can't find a supplier and mixed reviews on here
Primesat 1/1.1 - One negative thread on here but not much information otherwise
Are there any other newer production dishes I could consider, any recommendations which to go for? Often tune into feeds so every db matters but can't move up to 1.2 due to the dish location. Are gain figures a reliable figure to go off?
