Another Channel Master SMC 1m20 restoration X2
zorrin
Specialised contributor
France
www.facebook.com
france
Hi everyone,
I just found another 1m20 Channel Master. This one is motorized. Weather permitting this weekend, I'm starting to restore this one and my first Channel Master which is now 30 years old. The 2 ground stands are currently under construction by a friend.
2d784bec884801d5504d9beae924541bfe6bc3e9.jpgcd93083aada4b8952019721d698be0b9e75fbaf2.jpgIMG_6243.JPG
I also received this Nokia SAT1202 CS with a positionner ACU8152.
zorrin
France
www.facebook.com
france
Between two showers I started to clean the satellite dishes.
The 30-year-old is on the right.
Her back has been coated with boat resin to limit the Channel Master's fiberglass problems.
Manikm909
Small'ish Dish Man
Kent, UK
ive just realised from your pics - am i missing bolts fixings to fit the actuator ? or do they come with an actuator if bought new...
zorrin
France
www.facebook.com
france
yes they come with the actuator when you buy it :)
Yes, they are specific to the actuator design since they are of close tolerance to the rose joints at either end.
If you don't have the correct ones you have to find the appropriate spacer materials to pack out, or you end up with mis-tracking on a per satellite basis.
zorrin
France
www.facebook.com
france
I just received a photo of the two antenna feet. I hope to have them this weekend and start painting and concrete.
one is 2m and the other 2m50.
Tubes are 3mm thick, reinforcements and bases are 10mm.
Manikm909
Small'ish Dish Man
Kent, UK
Hopefully not 3mm and 10mm
zorrin
France
www.facebook.com
france
Manikm909
Small'ish Dish Man
Kent, UK
maybe 30mm and 100mm then
Manikm909
Small'ish Dish Man
Kent, UK
ah sorry - thickness - i get you now. i thought you meant width...
zorrin
France
www.facebook.com
france
i am so happy to share my experience with you and learn from yours :)
teltras
Channel Master 1.2mts superjack 18´´
Famaval 135PM Aluminium offset superjack 18´´
Famaval 1.0mts with diseqc motor Digipower SG-2100A
Andrew/Channel Master 1.2m with Jaeger SMR1224
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
Nice project, how is that resin treatment to prevent age on channel master?
Mine is also suffering from that problem, i can see and touch small fibers around the dish on top part and also on the back top half. Front dish is better.
I hope to prevent that with poliurethane paint.
zorrin
France
www.facebook.com
france
For my oldest one (30 years old), i used at the back a coat of marin resine. This is good but increase the weight of the dish.
this solution fixes the fibers that you currently find at the back.
on the front after a good degreasing i'm using paint but without metal inside.
zorrin
France
www.facebook.com
france
feedback on the project,
I followed your advice and went from 4 to 8 and from M10 to M12 for the bindings.
I have grounds for socket F.
Do you think I should put them on the king post straight or in a box?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
It is better to have them in the box, but not sealed, with good ventilation.
zorrin
France
www.facebook.com
france
Painting this weekend and comparison with the original base of the antenna which will go up to 2m.
A few years ago I painted my pole and polar mount in black Hammerite paint, it's now almost impossible to finely adjust azimuth as the painted surfaces stick together, so I have to rotate the pole. I'm not saying it will be a problem for you but it's something to be aware of :)
