TBS 6903-X useable with scanning apps?
Setting up IQ Monitor with a TBS 6983 for testing.
It's not scanning 27.5W. Just flat lining. Am I missing something in menu box? The HR spectrum mode shouldn't be red?
I made a video with the setting in IQmonitor to get high spectra with tbs6983 card,here
I checked now,high spectra with tbs6903X at 27.5 W.
The video is brilliant satesco :) Worth a thousand words...
I can see how each transponder appears now over the spectrum.
I will do some testing with my cards. Thanks.
Here's what a blindscan looks like without hs at 19.2E.This time with the tbs6983 card.
Regards
stephan94
Bavaria
Hallo Llew
if you want more information and still have the latest version of IQMonitor you can watch here:
This is where the developer " Strannik" indicates all the news
Hallo Llew
Thanks for that - information there and satesco's guides will keep me busy for a while :)
Regards
A small query satesco - my version of IQ Monitor (2.4.0.4) has the TSReader box greyed out. How do I wake it up?
As you can see,in IQmonit folder you can find the IQmonitor_2 .ini file. All you have to do is check if the applications are installed and have a correct path.
@stephan94 gave you a very useful link for IQmonitor.
I had checked the path earlier in the config folder. It's pointing to my TSReader.exe
Always works OK with Crazyscan, same path as pointed to in crazyscan config.
Honestly,I don't know why...:(
OK, thx anyway. Tried the app on a different Windows Home Premium PC (this one is Ultimate). I'll try it on Win 10 next, but don't think Windows is the problem.
Without a route to TSReader in the app it loses a lot of its versatility for me. However, I shall persevere with it :mellow:
Same blanked TSReader on Win10.
May not be significant, but every time I start IQ Monitor, before it appears, I get this "warning".
(I suppose it's just telling me it uses commas as the decimal separator. UK format uses full stops).
Just a check of my monitor with blanked TSReader. I'm using the latest IQ Monitor.
I didn't think you'd have the same problem.
You have to change the format,as you see in the picture.(apud @strannik at #727)
I'm already using dd/MM/yyyy :rolleyes:
I think only the US uses month before day.
Oh I see, just checked that post. I'll look into my settings. Thanks.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Just to say what is the x version about?
mariosrek
1.8 movable
Greece
Drop out also depends on the scan steps.It also depends on the signal strength.But anyway,even if you have drop out on the spectrum,Crazyscan will lock the signal.You'll get used to it.
On "Style" tab,uncheck "signal width",when there are several transponders close,parameters are seen/read better on the spectrum.
hello Satesco i can't find a way for a personal message, i was wondering if you can help me with the tbs6903X card? thank you. watching feeds with this card instead of 8922 at dvbdream i have a one or two seconds delay and i supposed it would be the other way arround..
kind regards..
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
kind regards..
Personal messaging is only open to members who have spent time on the forum posting.
kind regards..
I'm sorry,but I don't know how I can help you to change channels in DVB Dream without delay. It's not up to the user to improve this function but up to the developer,if he wants or if the card allows it.In the case of 6903x,I don't know which dvb player would be capable of instant zapping with this card.Although I'm not a developer,I can imagine that it's not easy to make a player work like clockwork.There are so many physical and software factors that influence this function, starting with the driver of the card itself.But about these technical aspects,the developers of these players would better talk.
I provide two files with 6903X and 6983 cards with DVBDream player. There are no big differences between the two in their use.
mariosrek
1.8 movable
Greece
thank you very much for your time !! is there any firmware that you know for the TBS6903X which makes the card download satellite data faster?? Thank you again !!
Maybe you mean a driver for the 6903x card! For now there is no other version than the one you see in the pic.
But better watch on the tbs page if a new driver version will be released.
mariosrek
1.8 movable
Greece
thank you again, very much !!!
