which feedhorn
v12nut
1.2mtr dish
spain
Hi all,
Setting up a 1.8 dish with Inverto quad and have a choice of 2 feedhorns from a friend, which would you pick? I think the Andrews is a Vsat horn.
cheers
What manufacturer/model is the dish?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
RimaNTSS
N-E from Riga
distance is an issue here, can only take one
Ask friend to send you both, and after tests send one back.
But, in 2 words, feedhorn #1 is for prime-focus dish, and feedhorn #2 is for an offset.
Hi all,
cheers
For Primesat 1.8m dish use the 1st one, it is for prime focus and that is the type of your dish
I have a Primsat 1.8 and as others have said it's the first pictured feed you need to use..
Hi all,
cheers
Post a picture of your dish from both the side and front.
v12nut
1.2mtr dish
spain
Just to let you all know I settled on the flat scalar feed and so far so good!
