IBU works well on Channel Master dishes. It is sometimes possible to get better signal from an Inverto Black Ultra by shading it from the sun, to stop it getting hot. There is a new version of the IBU coming out in the near future which may be worth waiting for.
Which firmware do you use on the F15? Version 1.25 or lower shows dB level below lock:
Hi, The series 1.xx and series 2.xx firmware for the F15 present very different menus with series 2.xx being like the menus found on the D15. Apart from the major graphical change to the menu structures are their any functionality changes that make series 2.xx firmware more popular? I have...
www.satellites.co.uk
In the UK I have the opposite luck with 26E - lots from Badr 4 but nothing at all from Badr 7.
