Trust
- Jul 18, 2004
- Age
- 77
- 1.8 m CM at SMR 1224 + Elev. with 7 lnb changer Ku (lin - circ) - Ka (lin - circ) C (lin - circ)
- Nijmegen Netherlands
I received such Strong SRT Digibox from Rimants (many thanks for that) and I was wondering what exactly is the use of those boxes .
The only purpose is to control a Diseqc 1.2 H2H rotor at a receiver or TV without disecq 1.2 motor control .
Programming (60 ch) can be done by the remote that has one button (Go to X) more than the Strong / Moteck V-Box remote .
Except for the Go to X command , the Digibox can also be controlled with the V-Box remote .
If there is no receiver connected , the motor runs at the 12 V power provided by the box himself .
Connected to a receiver or TV , the speed is depending of the TP polarity (13 or 18 V)
For that test I used a old Maxplus 2100 and noticed that if motorcontrol in that receiver is set to Usals , the Digibox will not react correct , 1.2 or OFF , no problem .
Pressing STORE +00+ENTER is turning to ZERO .
With GoTo X it should be possible by pressing Goto X + E (or W) for example +192 = 19.2 E . (if the rotor is provided with GotoX)
But since there is no option to store your Lat and Lon you can't set regulair sat positions and have to look to the calculations at Dishpointer .
I was hoping the display was also showing the value of pulses , so I could use it to build a more a advanced Usals positioner .
Unfortunality only program numbers .
I'm still happy with it because ist very usefull for controlling Disecq LNB revolvers .
