TSReader problem
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
not stream vlc :(
what is the problem? :(
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
I sometimes have problems with TSreader too, not that problem in particular tho.
I just reinstall TSreader without uninstalling, and reboot the PC, maybe try that?
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
I applied.
no change.
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Do you get an error message?
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
That's not an error message, that's just for info only.
Have you had it working before?
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Typical behaviour after a Windows update. Looks like an application reinstall may be on the cards and possibly reconfigure your settings in TSReader too. Clearly the output from TSReader is not being correctly passed to VLC. Can this be achieved manually by opening VLC and pointing it the correct port where TSReader is broadcasting to.
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Can you connect to the computer with anydesk program and look?
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
problem solved
port change worked :rolleyes:
Old port 1234
New port 1000 :cool:
Thanks all friend :-biglaugh
Satspot
1.2m Triax dish
Ireland
problem solved
Old port 1234
Change in configuration settings. Was there a recent Windows update or any changes made via your ISP.
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Satspot
1.2m Triax dish
Ireland
Who or what changed your port number so.
