You say Freeview but then say euro beam? No Freesat or Sat stb clears those channels, they are encrypted in tandbergJust noticed that Freeview versions of some UK terrestrial channels are on Astra 2G at 11608H. My Sky HD box doesn't support the 15480 symbol rate and on my Technomate HD receiver I'm getting sound but no picture due to encryption.
I'm in the UK next month, if I wanted to receive these channels which Freeview satellite box should do the trick if these channel stay on European beam?
Any help appreciated.
Sometimes the 27W group are unencrypted.You say Freeview but then say euro beam? No Freesat or Sat stb clears those channels, they are encrypted in tandberg
You mean the 27w Biss channels?Sometimes the 27W group are unencrypted.
FTA Gems
French Open (aka Roland Garros) jumps around ,France 2 to 3 and 4 (like Wimbledon or snooker does BBC 1,2,3,4) depending on time of the day. if you use French tv often,put France 4 in slot 4 and get rid of "canal plus",it 's encrypted anyway! (France 4 is strangely in the 14 slot in "official...www.satellites.co.uk
On a thread about Freesat in Newcastle ?my message was about French TV (on 5w) and how to follow the French open if you receive French DTT or 5W beam(the multistream one)
If you click the link it takes you to the intended post. For some reason the forum software clips the first post on the page rather than the post the link points to.my message was about French TV (on 5w) and how to follow the French open if you receive French DTT or 5W beam(the multistream one)
