Advice Needed Freesat, strong signal, 146 channels found but none are watchable.
RichofYorkshire
Panasonic Freesat TV, standard sat dish
Bridlington
Hi could your hive mind help me please?
I have just moved into a new house with my old Panasonic Freesat Tv, there was a Dish already on the wall.
I have plugged the TV in and gone through auto setup. It found Astra 2 and has a good signal and found lots of channels. and the channel list is there, it even has descriptions of the programmes. Sadly, when I click on the programmes it comes up with 'no service'.
It seems a bit weird does any body have any ideas?
Thank you in advance
Richard
Most likely the dish was previously used with Sky Q, which uses a different type of LNB that isn't fully compatible with the TV. A photo of the dish and LNB will confirm this. Swapping the LNB for a 'mk4 Sky quad' usually solves the issue.
RichofYorkshire
Bridlington
This is the dish.
Yes that's a Sky Q wideband LNB. If you're confident using a ladder it isn't too difficult to change.
You will get some channels on one of the cables if you carry out a full / slow scan.
RichofYorkshire
Bridlington
This is the dish and LNB.
Thanks in advance.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
An easier but more expensive option is to replace the box with a Freesat 4K receiver which supports the Sky Wideband LNBs. No ladders required.
Ah, the dreaded Arras box.
Changing the LNB is by no means difficult.
RichofYorkshire
Bridlington
It is not too high, thank you.
RichofYorkshire
Bridlington
What a brilliant forum this is, thank you all very much. Where is the best brand and place to buy a new LNB?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
You probably want one with multiple outputs such as this:
eBay
eBay
It would be good for the forum to have info on Panasonic Freesat TV models with multiple satellite inputs.
