Tony Jaques
- Sep 4, 2022
- Age
- 84
- Leyf 0301 80cm dish on 28.2E
- Manchester
Hi there,
This seemed to be the best place for my query. If it isn't then I apologise.
I have lost the remote control for my Leyf 0301, which severely limits the operation!
A replacement that I am considering, from Amazon looks good, and the supplier assures me that it will pick up the only channel that I require (Eurosport.de on Astra at28.2 19.2 E). But they obviously did not understand my second question, which was:
I don't need, and can't use HDMI. Does the SCART connector have RGB, or at least S-video outputs?
I am hoping that someone here has that receiver (or the cheaper non recording version). If so can you answer the question (by measurement if possible, or from that user manual if not?
Thank you very much
Tony
and hoping that this will work...
ADMIN EDIT - corrected Tony's typo on the orbital slot. A/S
Thank you very much
Tony
FULL HD COMBO Freeview HD + Satellite Receiver Compatible for FreeSat and Sky Dish Records by a USB Memory stick. NOT For SKY Q unless LNB to change: Amazon.co.uk: Electronics & Photo
Shop FULL HD COMBO Freeview HD + Satellite Receiver Compatible for FreeSat and Sky Dish Records by a USB Memory stick. NOT For SKY Q unless LNB to change. Free delivery and returns on eligible orders.
www.amazon.co.uk
