28.2°E 11306 H 27500 Channel 5 channels
28.2°E 11306 H 27500 Europe UK beam seems to be new, only one channel GC_PROMO at the moment, a slightly glitchy Globecast promo loop.
Now populated with assorted Channel 5 channels.
Manikm909
Small'ish Dish Man
Kent, UK
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Europe Beam for surely not, no signal on south Europe...
Thanks, signal seems to be lower than other UK beam transponders here so I assumed incorrectly, could be a skew issue at my end with 11306V also active.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - TBS5922H - Octagon SF 8008
Lombardy - Italy
Definitely UK beam since with my 180 cm (not perfectly aligned yet:() in Northern Italy i got only 6,5dB
Both beams showing 100% SQ with my SX88+ 10964 H 22000 & 11306 H 27500 with the 88cm mesh dish so both on UK beam.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
Now the same channels as 10964 H 22000
Astra 2E/2F/2G at 28.2°E - LyngSat on 11306 H 27500
the channels on both transponders are not identical
the info on flysat is incorrect
missing at 11306 h is NickJrPepa and the names of some of the channels are also different
the pids are also different from 10964 h
10964 h the line up is:
5USA
5ACTION
5SELECT
5STAR
5STAR+1
5USA+1
Channel 5
Channel 5 HD
NickJrPAWPatrol (coded)
11306 h the line up is:
5 Action SD
5 SELECT
5 STAR
5 STAR+1
5 USA
5 USA+1
Channel 5 +1 SD
Channel 5 HD
Channel 5 SD
one example
5 USA:
10964 h 22000 (SID: 7710/ VPID:2325/ APID:2326/PCR:2325)
network: BSkyB
11306 h 27500 (SID: 2102/ VPID:5101/ APID:5111/PCR:5101)
network: Five
on 11306 h there is no EPG
stephan94
Bavaria
of Northern Bavaria it can be seen that 11306 H (8.4dB )
is much weaker than 10964H (10.8dB )
with a 1.80m antenna (blue sky 6°C)
The channels are back on 11306 H 27500, this time with numerical labels rather than channel names.
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
My Value
cybertomanek
U2C Denys H.265
Poland
My Value 4,7 dB
Freesat is now using this transponder
newspaperman
125cm motorized Laminas 1200
Germany
Perhaps new HD versions of Freesat channels will soon appear :)
