Focal Lenght Ku-band
MrDish1
Delta Star
Qth:Aalten
A question;
the Focal length for the Ku band is the same as for the C band.
Because you see the majority on the Internet for the C-band
Best regards
A question;
Best regards
You've started on the sauce a bit early.
Focal distance is independent of wavelength at the frequencies mentioned.
MrDish1
Delta Star
Qth:Aalten
I am building a construction. And then it would be nice if you know what the dimensions are.
It's the same dimensions as in the two Focal point and f/D ratio web links calculators i sent you five days ago via PM
MrDish1
Delta Star
Qth:Aalten
Oke.
thank you John
Mvg
A question;
Best regards
The focal distance of the feed rim opening aperture from the dish for maximum signal level are different for C-Band and Ku-Band
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Here are two photos of my system and how the LNB' stand because of the focal length, I'm currently at 40.5W and watch Formula 1 on FS1 :D
MrDish1
Delta Star
Qth:Aalten
I didn't ask for photos.
MrDish1
Delta Star
Qth:Aalten
read my first line
what does it say there !?
A question
MrDish1
Delta Star
Qth:Aalten
Okay, I must have made a mistake without questioning it. ?!
@MrDish1 - you really could do with reading up on things before asking questions way beyond your current understanding. Most of the time, I have no actual idea of what you're even asking as there is no context, no sense and, like CH says, no question marks.
Politeness goes a long way.
