FTA Gems
Current leaders:-
1. George Russell (Mercedes, softs)
2. Yuki Tsunoda (Alpha Tauri, softs)
3. Esteban Ocon (Alpine, softs)
4. Lewis Hamilton (Mercedes, prototype)
5. Sergio Perez (Red Bull, prototype)
60 min to go for this session
Current leaders:-
Now 26 min to the end of ths session.
Fox Turkish currently FTA 42E 11305V 30000 3/4
Dggrr
VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
SE
20 Mediaset HD is back on 5w lots of US films & TV shows with English sound
12585 H 35500 2/3
broadcast in Multi-stream
Seems to have gone for me. I can lock stream 20 but no channels are scanned on my sf8008.
Also had Focus channel while it was working but no English sound track.
Data123
Golden Interstar Alpha X
65cm
leeds
Same with me using a Golden Interstar Alpha X
strange kingofsat & flysat are saying it still there!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
All ok here, Alicante, España. 1.2m GT Combo.
'Focus' audio only available in Italian.
Good luck. :Y
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Good luck.
20 mediaset and focus seem gone on my Edision MIO+ I could receive it but now I only get a data channel…
Adam792
Cheltenham
Looks like the T2-MI PID is 4646 (presumably it was the default/standard 4096 before), so that setting might need to be adjusted on receivers when scanning 12585H Stream 20 to receive any channels. In the same way as the Ukrainians on 4.8°E which use PIDs 4095 and 4097.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
How can we discover the T2-MI PID? It isn’t listed on lyngsat. it could come handy in the future :-)
Adam792
Cheltenham
I just found it from the DigitalBitrate scanner which scans 5°W, the only thing on the transponder is a data PID 4646, carrying ~33Mbps of data - DVBS DVBS2 DVBS2X Monitoring débit 12585-Stream-20 H Eutelsat 5WA/5WB
Otherwise, without a PC tuner, you can use dvbsnoop on the SSH/command line on an Enigma2 receiver, to see what PIDs are present on the transponder (it can take a while, but you get a list of what is carried by PID).
Adam792
Cheltenham
That PID (4646) is indeed carrying 20 Mediaset HD -
astra --analyze "t2mi://#t2mi_plp=0&t2mi_pid=4646&t2mi_input=http://127.0.0.1:9981/stream/mux/e3bfb954886b20364f80f50c82221089?pids=4646"
Nov 18 22:42:49: INFO: Starting Astra SM 0.2-event_monitor-2846c42
Nov 18 22:42:50: INFO: [t2mi analyze] L1-current: PLP 0 (Data Type 1), group 1 (*)
Nov 18 22:42:50: INFO: [t2mi analyze] selected data PLP 0
Nov 18 22:42:50: INFO: PAT: tsid: 128
Nov 18 22:42:50: INFO: PAT: pid: 16 NIT
Nov 18 22:42:50: INFO: PAT: pid: 202 PMT pnr: 3020
Nov 18 22:42:50: INFO: PAT: pid: 200 PMT pnr: 3200
Nov 18 22:42:50: INFO: PAT: pid: 253 PMT pnr: 2153
Nov 18 22:42:50: INFO: PAT: crc32: 0x970F9651
Nov 18 22:42:50: INFO: SDT: tsid: 128
Nov 18 22:42:50: INFO: SDT: sid: 2153
Nov 18 22:42:50: INFO: SDT:    Service: Focus (provvisorio)
Nov 18 22:42:50: INFO: SDT:    Provider: Mediaset
Nov 18 22:42:50: INFO: SDT: sid: 3020
Nov 18 22:42:50: INFO: SDT:    Service: 20Mediaset HD
Nov 18 22:42:50: INFO: SDT: sid: 3200
Nov 18 22:42:50: INFO: SDT:    Service: Test HEVC Main10
Nov 18 22:42:50: INFO: SDT:    descriptor: 0x50060901006E6F6C
Nov 18 22:42:50: INFO: SDT: crc32: 0xDFAC3301
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Unfortunately changing the T2-MI doesn’t result in finding 20 Mediaset… the Edision MIO doesn’t want to cooperate…
Dggrr
SE
Thanks all.
Changing the t2mi pid to 4646 works for me on SF8008/OpenAtv7.0.
Also, I've installed dvbsnoop!
For those of you needing fta access to the World Cup, the new Zero TV HD on 52E 10804H will be showing games. (Source - on screen graphic.)
Hash Mode 9 has not been broken for several years now and yet they still ask why MTN is not clearing it is not going to happen very soonmaybe never!
9E. 11823 H
Mandarin TV is in French, very odd.
rodscha
seems to be aimed at Paris'rich Chinese community,Mandarin Hotels are a Chinese Sheraton kind of
It s also on our Internet "boxes" under 600+ numbers,always fta
World Cup Football
Brazil v Serbia is FTA in UHD via the BBC iPlayer :D :Y
Intelsat 10-02 @ 1.0°W
11504 V 14400
DVB-S2 - 4:2:0 - 8PSK
FA Cup, Bristol Rovers v Boreham Wood 14:00 FTA
11486 V 14400
FA Cup, Burton v Chippenham 14:00 FTA
mikeisyou
Feed Hunter
England
RTE One HD FTA on Astra 2 (28.2e) 12167 V 27500 ID: 1204
