7W and 8W down in reception levels:only me?
rodscha
I used to get a good bunch of TP from 8w (with quite high levels) until Dec 15th, now nothing(Yemen,saudi,dubai,qatar...)
And a few,above 12000 ones from 7w ,(TV5Maghreb,Egypt's Nile TV bunch,Tunisia,Sudan muxes)when night comes.
Now nothing,when 5w and the 4,8E Ukrainians come as strong as usual, and the 14w Russians too,solid.
Maybe the Russians are jamming? lol
rodscha
will check this in half an hour. I used to get it,will see whether it' s still there.
rodscha
yes quite loud & clear
however 1)not the 2 "Hungary" beams
nor the strange "12297, H,45000" one,despite its beam being called "europe"? What may I be missing?
1.8 Channel Master, Uttoxeter in the UK
One failing polarity on the LNB ?
Manikm909
Small'ish Dish Man
Kent, UK
what happened....?
Just swapped it out so I could get my LNB changer back up and working. Precision is stored in the garage..
Manikm909
Small'ish Dish Man
Kent, UK
Ooooh - well let me know what you can squeeze out of 40.5 for ESPN then please mate......what DB reading.
Currently between 8.5 to 8.8 dB
Manikm909
Small'ish Dish Man
Kent, UK
Manikm909
Small'ish Dish Man
Kent, UK
Not sure what happened last April when I was getting near 10 or over 10. I think they changed the strength . Don't think it was FEC
Manikm909
Small'ish Dish Man
Kent, UK
@scopus - how long have u had the CM up for ? do you notice much difference signal wise between the two? do you favour one versus the other?
