Channel 5 on 11306 H
Nalleman
Motala Sweden
Sweden
Thanks for the info. Maybe my 1.80 dish won't be big enough in the future. From what I read HD transponders seem to have a weaker signal - I will have to update my receiver anyway if they switch off SD.
Should have added that BBC will remain in SD on 12 422 H until april 2024. That is the current plan at least.
curly wurly
180cm dish - Pace 430N - Inverto Black Ultra LNB
Northern Tuscany, near Viareggio, Italy
The problem when switching to HD is the use of DVB-S2 and 8PSK (instead of QPSK) which requires a stronger signal for stable reception.
Ok, I will bear that in mind.
You will need to do a rescan - all the residual SD BBC services are moving to 12422H & the existing SD transponders are being reconfigured for DVB-S2 8PSK. If you are using an SD only receiver you will have already lost 10818V.
Hwever the residual "Nightlight" services will close in April 2024
curly wurly
Thanks for that. I will have to get an HD receiver before then - from the UK I presume?
Depends if you want a SkyUK receiver or a generic one. Generic fta receivers can be found in many retailers, Sky boxes are probably easier to obtian in the UK although there are assorted expat resellers. Sky+HD boxes are no longer obtainable newe - Sky Q is the new big thing - & they need an lnb change.
Be aware that HD transmissions need considerably more signal than SD so if your signals are alreadty marginal you will need a dish/lnb/cabling upgrade
curly wurly
Thanks for your advice. The signal is ok in the winter 24/7 - not so strong in summer during the evening.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Do you have a smart TV with a satellite tuner? My LG is doing a pretty good job. Gets some BBC HD here on the fringe.
curly wurly
My smart TV is pretty basic so not worth the bother. I expect LG is far more superior.
curly wurly
Actually I never knew you could get a TV with a satellite tuner - it seems LG is the only make that have them from what I've found online.
Nalleman
Motala Sweden
Sweden
My brother has a Philips with built in sat tuner (which he doesn't use but it is there).
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
I would suggest to check wire and change the box to a new one with a good turner
From my own experience with older Toshiba TV's and the current LG (2-3 yrs old) with Sat tuners, I personally cannot recommend them - difficult to set up (poor instructions apart from anything else) and with fiddly controls in use. Separate boxes are a much better approach!
Nalleman
Motala Sweden
Sweden
Adjustments have apparently been made and now is 11306 H as strong as 11306 V and 11344 H/V. Well done Channel 5 (and/or Astra)!
Manikm909
Small'ish Dish Man
Kent, UK
my sony bravia 4k has a sat tuner as does my samsung qled
curly wurly
I will try those TPS - I lost channel 5 several months ago, so I appreciate your info.
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
No changes here, absolutely the same as previous several months...
Nalleman
Motala Sweden
Sweden
Here the same - nada.
Checked it on all my receivers now and there is quite a difference on all three receivers so it's not related to a specific recevier.
11306 H used to be around 9,5 - 9,7 db. 11306 V, 11344 H/V used to be and still are around 10,9 - 11,1 dB.
Now is 11306 H at the same level as the others. Checking it now and it is at 11,0 dB.
