Jaeger 1224 East West limits
Gonzologist
Jaeger 1224
Channel Master 1m
Manhattan 550
Wolsey Lacuna Mk 4 meter
Northern France, near Etampes
Hi, I've just moved my dish and can now see a wider arc but have discovered that the East west limits on the motor movement go from around 40E to 40W. I think this is capable of 70E to 70W
Does anyone know how to reset the East West limits? ( can't find the documentation that came with the motor, chaos caused by building work)
G
Burnham Beech
On old Jaegars there are two cams on a common spindle inside the motor box.
If the 1224 has the same system take off the motor cover and you should be able to see the cams.
Gonzologist
Jaeger 1224
Channel Master 1m
Manhattan 550
Thanks for that, BB, it is about 18 months old but I think it may be a different setup inside. Does anyone have an image of this?
Regards
G
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Hi guys,
I have a 1224 where the spindle and East West cams have separated from the cog they insert into. All parts look intact. The spindle shaft doesn't appear to have been broken. When I press the spindle down it doesn't stay compressed. Any tips on getting this working as it should?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I still cannot work out how it works with the rest of the motor, is it missing something?
Trust
Nijmegen Netherlands
make some punches with a centerpunch around the end of the shaft that must be in the cog , press it in the cog and make a Z clamp that you secure under the screw like on the picture to prefend the shaft to come out
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
@Trust I bow to your superior knowledge.
Can you say if the shaft was ever meant to come out?
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
The metal axis is fixed on the gear (red arrow) it cannot come out upwards, the 3 other parties simply slide over it.
Trust
The axis is fitting tight in the gear , not secured , once the tight fit is gone , the axis can slip out .
There are other ways to secure it but therefore you need to take apart the gearbox .
cardiff
Brittany
France
here is the axis and the gear on which it must be fixed
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
make some punches with a centerpunch around the end of the shaft that must be in the cog , press it in the cog and make a Z clamp that you secure under the screw like on the picture to prevent the shaft to come out
Please clarify regarding the center-punch, where the axis enters the location (marked below with a red arrow) the receptacle appears to be solid?
The axis goes through the plastic cams "normally".
Do you know how the axis fitted originally? The axis does not appear to have been snapped, it is rounded.
If I take the gearbox apart I will not have the confidence to put it back together.
Trust
The centerpunches make the schaftend more raw and wider so it’s more tight in the gear
Be shure to use a sharp pointer puncher
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Is this set made of the correct material to complete this task?
Trust
Yes , its perfect .
Just keep noted that the shaft must rest on a hard solid underground while punching , a big hammer or so .
