Closing the scalar ring
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
I did some research and found the ideal way to close and protect the lnb. The cappuccino cover fits perfectly.
basically no signal loss at least on the ku band LNB
On weak signals after rain that lies in the exposed scales can be a problem for me. I use a cover that covers the whole feedhorn.
Trust
Nijmegen Netherlands
Does the inverto twin need a extra cover ?
Inverting the reflector eliminates moisture entering the scalar internals.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Ali inverto twin potrebuje dodatno prevleko?
It doesn't need to. However, dirt does not accumulate inside the scalar ring
