Just Sharing This Summerly routine
Satfaca
Melmac (46N, 14.5E)
Melmac
Summerly routine ... performance intact ... however appearance needs some tune-up. :)
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Beautiful antenna. When you wash it all the way, it will be like new.
Which dish is that? Pretty!
As per the profile, a 1340 Prodelin 3.4m
Easiest way to bring back to a full parabolic is to tip the dish to look upwards, loosen (not undo) all the reflector and support bolts, and give it a really good shake. Then tighten from the outside in.
The 2.4 would be a three piece reflector (1251).
coinhas
Hispasat
Jersey
This is one big dish. Dam
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
The small one appreciates some treatment as well. The pressure washers really is one of the best investments in life...
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
This is the lnb I sent you. It is hunting the Ka band on the 1.2 m antenna.
Satfaca
Melmac (46N, 14.5E)
Melmac
Now it shines bright again. :cool:
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
It's like new - I like it.. Do you only use vap or something?
Satfaca
Melmac (46N, 14.5E)
Melmac
