Forum not loading using mobile Internet
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Hi All,
I have for many years been able to use the forum using mobile internet on my mobile device. Using the same equipment over the last few weeks (I guess) the loading has stopped working.
Android 9
Chrome and duck duck go not working
EE network
Maybe ok for others?
Have there been any technical changes preventing the forum loading on mobile?
Works on O2 network here from my 'droid.
FWIW but probably not very relevant, Firefox with duckduckgo works fine on my Android 12 Motorola G30 (and on W10/W11 PC's) on GiffGaff (and thus the underlying O2 network on which that is built).
pontiend
Contibruter
south yorkshire
Works fine here Android 9, firefox focus.Duck Duck go.Vodaphone network
Hi All,
Android 9
EE network
Might be an idea to describe what happens when you try to run Chrome+DDG, and also if you choose different browser and search engine combinations.
PS: ignore "Fijian01" at the top!
sonnetpete
wordpress.com
Normandy, France
Working fine here via Chrome on an android mobile and Bouygues 4G modem.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
After further investigation by entering the address directly into the address bar and then clicking around, the forum does eventually load but very slowly, takes about 10 seconds at least.
No problem loading other sites using the same EE SIM.
I have another EE SIM in an Android 6 phone with the same behaviour regardless of browser.
Manikm909
Small'ish Dish Man
Kent, UK
Sounds like you have a DNS issue - very odd though. Ok when on WiFi ?
All ok with me, in 4G as I type this..
Manikm909
Small'ish Dish Man
Kent, UK
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
WiFi has always been fine.
Have used 2 different phones with an EE 4g connection both same behaviour.
Reports coming in from members saying theirs is working, if so do you have an EE SIM?
Manikm909
Small'ish Dish Man
Kent, UK
My posts are being moderated
Manikm909
Small'ish Dish Man
Kent, UK
It's not just you, for some reason all posts in this section go to the moderation queue for approval.
Manikm909
Small'ish Dish Man
Kent, UK
Ah ok . Thanks
FWIW, same moderation problem here (and on previous occasions in this part of the forum)!:rolleyes:
I think it may be something to do with posts being allowed from non logged in users?
If a member loses their login details and need to contact the forum admin for assistance in regaining access this section is where they would post.
Presumably, due to non logged in users being able to post, all the posts require moderation before being approved for visibility on the forum?
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Hi All,
Android 9
EE network
Clear the cache and all cookies on your browser and try again.
Must admit that I regularly forget to do that when similar problems happen on the PC's - which, BTW, seem to happen quite a lot with Firefox+DDG, and so I then use Chrome+DDG, which usually does work.
Therefore I think this, and a lot of similar problems, are due to either the browser &/or the search engine not being set up "correctly" - but TBH it's generally difficult for the "average guy" to know how to actually "set them up correctly", and thus what/what-not settings to apply because of the very complex options menus. Thus we tend to live with what we have because that "works most of the time", and then "work around" that when it doesn't! :(
@ozumo : any chance that you could get someone on the Staff to look into why & how this is happening - and then remove the requirement if it's not relevant/important?
