atl68
- Jul 19, 2021
- Age
- 55
- Channel Master 1.2m at DM3800, GI-211 LNB, VU+DUO, Vantage 1100s, PRO Omicom 16/32 Card.
- Czech Republic
Thanks for your reply and time with measure the feedarms. Problem will may be with LNB holder. This one is really nice without any damage.Nice dish, congratulations! I have one brand new, never installed, even it more than 30 years old. Polar mount and feedarms are also present. Can measure the feedarms during the weekend and measure them.
Edit: I think we already spoke about the same dish some time ago. So, you have all the data you need Old Satellite Dish
Agree with you partially. Taking in account that original LNB holder is designed for 23mm LNB-neck, you need new LNB-holder anyway. But making LNB-holder for existing feedarms (open ends of 18,5mm tubes) is pain in the a*s, it is much easier to create completely new setup (feedarms + LNB-holder). Moreover, if new feedarms have length-adjustment possibility, then all assembly will look, and also work, more sexy.why not copy them ?
