30 W Feeds
it two channel uhd trasmited ?
EnoSat
enosat.euweb.cz
Slovakia
yes (TVE UHD with HDR, UHD-2 with SDR)
EnoSat
enosat.euweb.cz
Slovakia
Other interest tests INGEST TELECOM are running on 11222V and 11422H
it doesn't show me any stream, but the identification data changes very quickly (maybe some DVB-IP or something else)
Satfaca
Melmac (46N, 14.5E)
Melmac
Very strange streams... ACM mode, continous stream, with Multistreams.
On 11.422 H there are two MSs with fixed numbers (0 & 254) while on 11.222V are 16 MSs with constantly changing numbers.
11221 V,30000,2/3,8PSK-generic stream
11422 H,30000,8/9,16PSK-generic stream
e2 boxes can lock the signal?
Thats the Albertis transponder. Its transmitted in an odd way - there is jiggery pokery with BISS encapsulation of the transmission pids.
There used to be a guide on the forum with hints to opening it although we had to delete it as too many folk were demanding the keys to get it open.
Wrong polarity - 11222H is Abertis, the transponders with the new tarot channels are 11222V & 11422H. I say new but seem to remember they were available for a short time (last year?) with the same SAT TEST channel names and could be received with any receiver.
Edit: Perhaps longer or further back than I remembered
rodscha
a lot of "procesiones" on the usual Astra "andalucia,galicia,aragon,extremadura" channels & the Hotbird TVE Int
Colorful and handsomely commented!
Whilst the internal search engine prevents me from looking at La1 / La1HD plus 24h/HD, I appear to be getting a good signal of SD and HD channels on this satellite - 12670 V 30000, and in the clear (but the GT Combo may be playing trickery even though I've not set it up)
Not on Lyngsat hence the post.
Karate Kid is allegedly on in a couple of hours in both German and Spanish (oh Joy !)
Some of Tenerife is on fire btw if people want to check on family
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - TBS5922H - Octagon SF 8008
Lombardy - Italy
It' an Abertis Trasnpoder and yes, you're right, the GT Combo plays trickery! It have all the abertis information hardcoded in the firmware so a simple search will clear all the Abertis packages.
It's non on LyngSat because i don't know why he doesn't list the Abertis Package but if you look on FlySat you can see the TP vas reported by EnoSat on 2021.
Bye,
11998 V 7199
Ponte al Dia
Comes up as E220 Mod Via 1
I can't check with another receiver at the moment, but LA1 and LA2 are both viewable on 11302 H and 11382 H (SR 29999) it may just be the GTMedia Combo that has this ability though.
Neither frequency is on the Lyngsat site
maxi_power
120cm motorised dishes
PT
Maybe,
I pick up a lot of radio channels and others without reference, but not these two.
Octagon SF8008
cirio70
Lombardy - Italy
It's the GT combo.
The 2 frequencies you mention are part of Abertis Package. The GT combo has the ability to clear the package but SF8008 and others needs astra script.
https://www.flysat.com/en/satellite/position/30-w
It's the GT combo.
And yes, it has found the other frequencies from the package before (eg 11347H /12631 V), but they are stored in the T2MI list (not on the 30W), and selecting these sends the receiver into a loop. Can they be cleared ?
maxi_power
PT
It's the GT combo.
I didn't even remember that, I thought it was new frequencies. Yes, in the abertis pack these channels are there and they work fine on SF8008.
