Wanted 1m Prime Focus Dish
dreambox1959
46.3N-4.3E-FRANCE
france
I have been looking for a long time for a prime focus dish of about 1m (for my tests with the EGIS engine) but in continental Europe.
or possibly from the UK but with the help of someone coming to France on holiday.
if someone has one in france it would be ideal.
the price is negotiable, of course.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
My friend is selling a prodelin of 1.8 m. The ad is here - the country is Croatia
dreambox1959
46.3N-4.3E-FRANCE
france
thanks Beli but i want a prime focus (i had offset yet) and about 1 meter to be able to get it easily (by car or delivery)
it s just to put on my EGIS motor (for my firmware tests )
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I see. If you might be interested, a friend of mine has been doing some tests with the Egis motor on this very antenna. There is some video footage. He is also interested in building your positioner and will probably contact you shortly. I think he can give you a lot of useful information based on that he is an expert in satellite systems.
You can watch some videos
Egis motor-prodelin 1.8m test
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
A bit off-topic:
You could always use an offset that you have lying around, mounted 90 degrees rotated?
As here: Parameters
Then vertically, it is not offset anymore.
Greetz,
A33
A bit off-topic:
As here: Parameters
Greetz,
A33
It has been common practice around here since the 90's, usually to keep a low profile from the neighbours, but also aids installing a wall bracket on a parapet.
Manikm909
Small'ish Dish Man
Kent, UK
A bit off-topic:
As here: Parameters
Greetz,
A33
how is that any different from traditional install? if the LNB is at the bottom or sideways - whats the different aesthetically? please clarify.
Well.....
The dish face is no longer almost vertical, and so the height is reduced.
Since the reflector now follows the angle of elevation (more or less) as opposed to the built in offset, it will throw less of a shadow onto anything nearby.
Depending on which side the dish is installed, it can be better matched to a roof that sits behind it, either bolted into the gully, or on a pole through the tiles.
Manikm909
Small'ish Dish Man
Kent, UK
Well.....
ah yes i see, thanks.
a33
XSAT410
Rebox RE-9000
The Netherlands
The egis motor has a limited elevation range, making it more difficult to fit an offset dish to that motor.
So it is not an aesthetical thing, with an egis motor, but a practical thing. See the webpage I linked: good solution!
Greetz,
A33.
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
dreambox1959
46.3N-4.3E-FRANCE
france
really good but it s long way for me from middle of france .
