dreamsat
- Mar 23, 2018
- 2,20m Kathrein, 3,7m Andrew, KU,KA,C,C-Ext. LNBs
- germany
Thanks, @hvdh for the link.Recently, Eutelsat website shows downlink coverage maps for 10B as well:
"HTS Downlink" and "GMS Downlink" (what is GMS?) seem to be composites of the many spot beams that both HTS payloads provide.EUTELSAT 10A | Eutelsat Satellites | Eutelsat
EUTELSAT 10A is located at 10° East, one of Eutelsat’s long-standing orbital locations and a key position for data and professional video networks.www.eutelsat.com
A map for Widebeam Ku-band, for continuity of 10A existing customers as they say it, is still missing.
Satbeams shows it, however.
When you feed the same signal to the e2 box, it analyzes another mode (identification)
View attachment 151960View attachment 151959View attachment 151964
PS:1 Subsequently, addressing of the processing of the stream(s) on the IP bus of the modem begins
Box with AVL6261C chip (Si21xx gives very disappointing results) and modified FWEnoSat,
Great information. Please can you confirm the E2 Image and box you used for this?
Do not forget that it is not broadcasting, but testing of transponders for work with DVB-IP"OSN BACKUP" suggests maybe it's used to OSN in MENA?
Robert, on the 3E I get Nyota TV on 4032 RHC and on 10E I get MonCloud TV on 4027 RHC and Tchad TV on 3860 RHC. These must be the easiest to lock as I only have a 1.2m CM dish.Hallo, this is Robert from Uganda, can you help get me the strong TPs for Eutelsat 10b & Eutelsat 3b on c-band.Thanks
Thanks, but I have a 1.8m dish and I wanted to get East African local channels.Robert, on the 3E I get Nyota TV on 4032 RHC and on 10E I get MonCloud TV on 4027 RHC and Tchad TV on 3860 RHC. These must be the easiest to lock as I only have a 1.2m CM dish.
