26E (Badr-6) MENA Beam
dreamsat
germany
12456 H 27500 DVBS/QPSK 3/4
dreamsat
germany
current scan in H
Satfaca
Melmac (46N, 14.5E)
Melmac
Here's the complete oversight of BADR-6 transponders, it will be interesting to compare if/once they switch to BADR-8.
Locked (with 2.4m):
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
On which antenna do you have these measurements?
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
This debate should continue here.
Badr-6 has gone...
rodscha
zapping from 12284 (mbc ,Badr5) and 12563(Mauritania,Badr8)I do have the 0.3°symptom.
When pointed at Mauritania,no MBCs ,and conversely,on MBC,no Mauritania...
Propagates a tad better in the morning...
60% on Mauritania is a minimum to lock it in HD
MBC has a much stronger signal.
The only frequencies now listed by Flysat for Badr-5 as of today are data frequencies and nothing at all is listed for Badr-6.
As there are several members who have reported the 0.3° symptom it might be worth checking later today to see if I am still getting the symptom.
Back later.......
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I checked in the morning. For example, the mbc channels are on 3 frequencies. The channels in the HD version are offset by approx. 0.2 degrees on my antenna. The signal rotates around 8.5 to 9db. Just a little above Lock. For example, 2 rotana channels also broadcast on 2 frequencies - clean same example. I can lock all frequencies, but corrections are needed. I will mainly make 2 positions of this satellite in the settings list and in this way I will have a max signal, which now deviates if I want to lock mbc hd channels and rotana hd.
