Advice Needed Receivers with the lowest Symbol Rate?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Today, 1.8m, totally clear sky, 18.2ºC.
Octagon SF8008 4K Twin.
23.5ºe 12647 V 285 DVB-S QPSK
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Secured a little bit lower frequency than my previous, so today:-
Alicante, España. 14.45hrs with 16.7ºC Cloudy
1.8m Marrafa PF, Inverto Flange Quad C120.
8.0°w Eutelsat 8 West B
12622 V 256 1/2
¿Nothing at the mo but has anyone lately secured (shown 02-2023, Flysat) 8.0ºw 12621.46 V 144 2/3? :Y
Adam792
Cheltenham
12622 V 256 1/2
View attachment 154320View attachment 154321View attachment 154322
I have once on SDR about a year ago. It contained Tendance Ouest as listed on Flysat.
EnoSat
enosat.euweb.cz
Slovakia
In addition to low SR, can someone verify high SR as well?
For example:
8West - 3749L - DVB-S2/8PSK/T2-MI - SR-45830 - FEC-2/3
PS: It's a pity that the T2-MI with SR-60000 was already switched off
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
For example:
Not much time at the mo but a little higher:-
25.5°e Es'hail-1
11174 H 47615 FEC Auto - DVB-S2 - Data:-
EnoSat
enosat.euweb.cz
Slovakia
not DATA , T2-MI or MIS , since the Si2166 cannot handle it ShortFrameRate (only normal -LongFrameRate)
jsda30
edision os mio 4k
spain
Uclan Ustym 4K Pro with sr of 250
hi stephan94
finally blullseye 10khz lnb arrived here!
it have 2 conectors red and green, which ill must to used?
the tuner configuration its the last you sent in another post isnt it?
ill test with octagon sf8008
EnoSat
enosat.euweb.cz
Slovakia
jsda30
edision os mio 4k
spain
thanks again enosat! but i dont use with rtl-sdr usb.. direct with my octagon sf8008
you know if i must use a power 12/18v because i have a 16 century disec
EnoSat
enosat.euweb.cz
Slovakia
It doesn't really matter if you use the 12/18 or 13/17 power supply from the SF8008, the main thing is to connect the cable to the correct connector
jsda30
edision os mio 4k
spain
I am also happy with my old SF4008. As mentioned by tompouce last drivers supports SR around 500, with old drivers not a problem even with SR 256 (scan + listen). "Old drivers" also see SR 186 for example on 30W but I can't scan it. See pictures attachment. SF8008 is still the best STB for low SR.
hi master.. great...
i can see that you can get sr 185 hispasat.... you get with old octagon sf4008? manufactured year? image?
hi stephan94
I found the LNB good, but the Fracarro twin LNB (UX-TW frm memory) just edged into the lead in terms of fringe reception.
Satfaca
Melmac (46N, 14.5E)
Melmac
jsda30
edision os mio 4k
spain
hi everybody....
yesterday i installed de bullseye 10khz lnb but not get signal at 26e
i have octagon sf8008 with openatv
need a special image?
special configurarion on box?
thanks for the help!!
jsda30
edision os mio 4k
spain
hi stepham yesterday i installed bullseye 10 khz lnb with my octagon sf8008 and not signal
need tnap image?
which image you used in that screenshot? skin?
im using openatv
can u sent complete turner configuration?
thqnks in advanced!!
jsda30
edision os mio 4k
spain
thanks a lot
im using bullseye 10khz lnb... i think thats for that channels...
in the manual are talking about octagon sf8008 mine its combo.. but same turner...
also turner configuration are single lnb i have diseqc....
ill test again....
thanks
hi everybody....
I have twelve transponders from the satellite on the 1m dish here.
Has somebody put washing out ?
jsda30
edision os mio 4k
spain
hi... thanks again for the info and pdf instructions...
on that pdf file said that on tuner configuration i must to insert the lnb input.... on that pdf said 9388
i have bulleye lnb special for 25e satellite.. where can i see the input for insert on my box?
thanks
stephan94
Bavaria
even lower with the openbox S3CI II,
this time NRW radio on 23.5 Ost with sr 285
Encode_1080P_88.mp4_20240328_154832.403.jpgEncode_1080P_89.mp4_20240328_155312.357.jpg
