Advice Needed Irte dish
Heeres
Ik heb 2 schotels offset van 1.20 meter voor tv ontvangst en 2 prime focus schotels voor mijn pc
Sondel
Hallo allemaal, Ik heb hier nog een oude Irte antenneschotel staan die ik wil opknappen, maar wat voor LNBF moet hier op de schotel komen? D is 150 cm in diameter en D is 16,8 cm, wat mij een f/d-verhouding geeft van 0,56. Ik zou het graag willen gebruiken voor ku band en is er iemand anders die hier misschien nog tekeningen van heeft?
Hello everyone, I have an old Irte antenna dish here that I want to refurbish, but what kind of LNBF should be placed on the dish? Dish is 150 cm in diameter and depth is 16.8 cm, which gives me an f/d ratio of 0.56. I would like to use it for ku band and is there anyone else who might have drawings of this?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Heeres
Sondel
yes thank you for allowing me to use this form and thank you for the advice
Channel Hopper will be along shortly....
Only to suggest what has been imaged is not the usual 1.5m IRTE.
One hole in the rim every 90 degrees.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
So, a different IRTE dish, with other specifications, see Just Sharing This - IRTE Dish Specifications ?
f/D = 0.56 is different from f/D = 0.41
What feedhorn to use on a f/D 0.56 dish?
Greetz,
A33
Not quite.
images
a33
XSAT410
Rebox RE-9000
The Netherlands
So the 1.5m IRTE with f/D=0.5x, with extension petals becomes the 2.0m IRTE with f/D=0.4?
"Interesting" way of having a range of dish sizes....
Greetz,
A33
Search for 'Christine' and 'Evan' on this site.
a33
XSAT410
Rebox RE-9000
The Netherlands
I couldn't find anything relevant.
Also not with IRTE and vipersan
Also not via google....
Very strange
a33
XSAT410
Rebox RE-9000
The Netherlands
Very strange
I didn't find that this was an IRTE dish, or more specifically the 150cm version.
In the first pages of the topic (that I had indeed found) IRTE isn't mentioned.
So I found it irrelevant for the subject at hand....
Greetz,
A33
Greetz,
A33
You appeared to be interested in ratios when the diameter is increased on a specific parabola.
a33
XSAT410
Rebox RE-9000
The Netherlands
I'm afraid that is a rather bad summary, of what I was interested in...
:confused :(
I've read post 8 again but can't see anything between the lines.
If it helps Prodelin also increased their prime focus dish range with panel extensions.
