Telstar 12 Vantage.
juventusbrown
amazonas & claro 125
barbados
Hi guys, this is my first post on this site and I've been reading this telstar 12 section for about 2 weeks now but what I'm about to ask is a long shot. I live in barbados in the Caribbean using a channel master 8ft offset dish work I be able to get this telstar 12? And are these channels ku under biss? Just trying to make sure I ask the correct questions and that I'm clear to anyone that replies thanks.
Satfaca
Melmac (46N, 14.5E)
Melmac
You definitely can receive the Caribbean Spot & The Panamerican beams, most probably the Brazilian as well ... and that's it. If your idea was to receive the british SatBack ... sorry no go.
Footprint
Nalleman
Motala Sweden
Sweden
There are different beams and you should be able to get the Pan America beam without problems. Most channels are encrypted though using Verimatrix and StreamGuard (simulcrypt).
The Nordsea beam containing BBC and others (BISS encrypted) is well out of reach at your place as is the Europe and Middle East beam (not much of interest except ESPN (BISS encrypted) on this beam.
juventusbrown
barbados
Thanks for your quick replies and feedback. One of the reasons I ask is at the moment I get hispasat 30w and intelsat 34w, so I know telstar 12 would be a bit down from intelsat 34. You can even get hispasat 30w and intelsat 34w with a 4ft dish here.
Nalleman
Motala Sweden
Sweden
You can always try!
In some cases there are sidelobes and if you are lucky you might get one.
The chance of getting the North Sea (I'm in Sweden so autocorrect preferred "Nordsea" in my previous answer) beam is none I would say.
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
You can always try!
Nalleman, i see that you are somewhere in Motala, what about your BBC reception via Telstar? According to you profile page, you have 1,8 Channel Master, how does the spectrum and that huge 100mhz transpoder looks like for you on a 1,8cm? do you have crazyscan and can you show us that part of the spectrum? ( I'm just a little bit curious and would also like to know if you get Astra 28,2e uk beam?)
Forum member dmaavrigdom, he gets it in Vansbro with 80 cm dish.
Nalleman
Motala Sweden
Sweden
The 1,8 m dish is fixed at 28 E. I'm getting all channels there without problem with the exception of 11053 H which is hard to get sometimes in bad weather.
This means I haven't tried the 1,8 at Telstar.
juventusbrown
barbados
Thanks for all the info and suggestions if I do give it a try I will come back with some feedback
Guys, what size dish are you using for this Sat? My 2m dish and icecrypt box pick nothing up.
Are you getting any signals from the satellite ?
picobird
Several dishes but been working on getting BBC sat back up & running again
Serta, Portugal
Yes I am getting signals from the satellite (Telstar). Mind you it’s taken nearly two weeks of messing around & finally just before the Man U v Chelsea match.
I am using a newly bought 120cm dish which is damaged hence no BBC 3 or BBC 4.
My location is Serta Portugal.
Off to pour a glass of wine, my box is a Gt media V8 which I also used on Intelsat 901.
DPD have got a lot to answer for but that’s another story.
I can only use a cheap satellite finder as I am used to it.
Try BBC3 & 4 after 7pm ;)
(They are part time channels sharing with the kids channels)
picobird
Serta, Portugal
Thanks for that
Analoguesat.​
There I was worried about missing RuPaul ( a bunch of very clever guys).
picobird
Serta, Portugal
The signals are starting to break up a bit but I am not going to touch the dish just yet.
During the past two weeks I have picked up Hispasat (yet again) on a decent sized dish compared to my mini Hispasat dish. The extra FTA channels are brilliant with several free ‘film channels’. Tuning to Hispasat takes about a minute with my painted markers on the ground.
Should these cloudy conditions persist I will tune into the other dish as I enjoy the Spanish language & Spanish channels. We had a packet of rain this morning (thankfully) but we are headed into six months plus of clear skies now ( in central Portugal).
At least I can continue with a Vodafone.pt data sim for internet use (about €1 day) & forget about cheap satellite internet as my dish picks up BBC satback again.
Thanks to all the advice regarding ‘locations’ from other posters.
What seemed to be a ‘closed chapter’ is going onto ‘better times’.
The signal is getting better (very clear) so there is a bit of ‘iffy’ with Telstar compared to the ‘cast iron‘ Intelsat 901.
picobird
Serta, Portugal
The Telstar 12 signal went off about 9am & I have been using two satellite finders today ( both finders have their merits).
Rather fancy that the bods at the ‘other end’ may be tweeting things as yesterday was okay. In fact the signal was at 95:85 (strength/quality). Right down today though.
Anyway, I have ordered about €15 of tools from AliExpress which will keep me amused in the weeks to come re two dents. As the dish is not warped it will be worth spending a bit of time on.
In Portugal there are only a couple of satellite dish suppliers worth using, the others want to charge ‘silly money’.
Fingers crossed that at going home time (bods at the other end), the signal will increase.
juventusbrown
barbados
Ok update, nalleman and satface and all others I found the 15w here in barbados with quality in the 80's on transponders and you were right I got the pan american transponders but didn't get the bbc transponder which is the north sea one.
Any other suggestions for a man like me in the Caribbean getting a block of those bbc channels on any other satellite?
picobird
Serta, Portugal
JuventusBrown
You could try a Filmon subscription for their streaming service, personally I find satellite has a better picture.
In the meanwhile Kabelio seems to be the way to go, thanks to all those on this site who mentioned this lifeline.
The Telstar signal is just too temperamental until I can find a solution. :(
juventusbrown
barbados
Pico thanks for the suggestions but we that love satellite streaming is too easy we prefer the hard work of fighting to get it on our dish, I hope you understand what I mean as dish men together.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
What time today should I align the dish? Why does the signal disappear when I get ready to adjust the dish? Why am I not seeing a bigger difference between the 80cm and the 1m? Which LNB is best on which dish? Is the SF8008 more sensitive than the Supreme or is it the LNB or the coax?
Yesterday was hopeless but today it's fine! I think they moved the satellite. tle.jpgtle.jpg
RoyH1
1M dish, icecrypt box, astra rx bbc (arqiva) now defunct bbc satback. need to realign to telesat.com
Algarve, Carvoeiro, Lagoa
Yesterday was hopeless but today it's fine! I think they moved the satellite. View attachment 155687View attachment 155687
Hi
Im a new member and not sure of the rules etc. I'm on the Algarve and have lost my satellite reception for UK Tv via the Arqiva BBC satback service. I understand that telesat have an alternative service does anyone know if this will work for my area and any further details Many thanks
