sky cowboys
tesy
raven 70cm dish for 19.2/28.2 and 13e
cornwall
Just been over to my mums to sort out a bl--dy sky instaler . The pig was instaling sky to one of my mums neighbours so insted of putting up a dish he pulls my mums lnb out and replaces it with dual output lnb and feeds it into next doors flat , the first thing my mum knows about it is when the tv goes blank . So she looks out the window only to find this d--k with a cable in his hand , he then disapears next door without a word.
luckly I live close to hand so shot over there and had a few words with him like what the f---k is going on.
His excuse that the council was on his back about too many dishes going up and they were watching him:-Cgrin
Get onto Sky customer services and complain about the shoddy practises of their subby installers. He was probably running behind on his installs that day and took the quick route rather than the correct way of doing things to install the extra dish.
As the dish is on your mums property you are quite within your rights to disconnect the second cable! :D
tesy
cornwall
Sounds like a good idea , Talk about bl--dy cheek and I have just rememberd he still has my mums(who is 75 by the way) lnb the ba----d a cowboy and a robber
BonceChops
Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100
NW England
That is unbelievable, the cheeky so and so
pgh13
Midlands UK
Potentially dangerous I would have thought; there's no guarantee the 2 premises are on the same phase supply
moosegoose
bog standard
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
norwich
could you explain why pgh13 i have shared dihes before with owners consent.with no problems.
The potential between tw phases is 400+ volts, the LNB feeds in these circumstances should be earth bonded, so that any dangerous voltages go to earth.
All multi user systems in apartment blocks have to be earth bonded for the above reason.
Having said that, many people share LNBs and aerial feeds without bonding and I have never heard of an accident caused by this, it is nonetheless potentially dangerous.
I would disconnect the other feed, he had no right to touch your Mum's dish, it does not belong to Sky.
koansrc
CM 3.0m @ 28.2 w PACE
Athens-Greece
I think a lawyer would enjoy sinking his/her teeth into something like this. Trespassing comes to mind alongside theft and who knows what else. Don't forget to get the neighbours on your side too. They are probably also assuming they have their own sky dish and lnb.
As for the admitedly ugly dishes sticking out all over the place, part of the problem is that the installers will always install in the easiest position. There may well be other less obvious positions for a dish.
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
it happens quiet regular this practice.
happened a few times in my street
tesy
cornwall
Have now got sky to disconect my mums neighbours feed from her dish and return her equipment to as it was and next door now have there own dish.
The guys who did the work said that it was a right mess before.
Yeshi
Norden - Near Edenfield (not Rochdale)
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
Ive done this on installs , dont see the problem.. bearing in mind i only did it on extreme circumstances... ie no line of sight... but on this occasion the owners rents live 10 doors down... there was no Cable and had 60ft trees in his way.. it was lucky his rents had the end house as they had los... we down however have to drop the cable in the gutter and did my speciality on that.. i call it whipping.. 1 person holds the cable one side and i whip it into the gutter on the other..
That wasnt an ideal install but it had to be done..
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Tesy
Didn't the neighbours wonder where their dish was going to be sited when the sub arrived??
Like ..... "where's the dish".
v9oly
Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams.
South West
The potential is 400v+ between phases when the phases are at 230v, is the lnb voltage is about 50V? Would be interesting to know what the voltage across the two lnbs was (assuming different phases), I'm sure it would still be considered potentially lethal as anything over 50V is.
All the best,
Ollie
It isn't to do with the LNB voltage, but if for some reason full mains voltage is passed up the coax cable due to an equipment fault.
v9oly
South West
Hi Rolf,
Wouldn't fancy being on the end of that regardless of three or single phase:-wow
Regards,
Ollie.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
v9oly said:
Hi Rolf,
Regards,
Ollie.
Yes, One phase does hurt a bit:eek:, I 've touched the live wire many a time when I was a kid. ( I used to wire things up. LOL) Two phases however, is rather more dangerous, and it is important that you can't touch both of them at the same time.
Scott Nelson
Sky HD and Sky Multiroom
Essex, UK
Agreed. I've known this kind of practise to happen in apartment blocks not far from me.
karat
technomate, t rex cam, cerebro, fun 6, gold, firecrypt. win xp pro.
tyne & wear
stick lnb's to street signs, there's to many of them. kill 2 birds with 1 stone, those nice round ones? could also try lnb's to speed cameras, make them more usefull.
aba
chaparral montery 40 fully loaded
ehcostar ad3600ipvia
3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
nottingham
Yeshi said:
Ive done this on installs , dont see the problem.. bearing in mind i only did it on extreme circumstances... ie no line of sight... but on this occasion the owners rents live 10 doors down... there was no Cable and had 60ft trees in his way.. it was lucky his rents had the end house as they had los... we down however have to drop the cable in the gutter and did my speciality on that.. i call it whipping.. 1 person holds the cable one side and i whip it into the gutter on the other.. That wasnt an ideal install but it had to be done..
i take it you left the coax in the gutter
all i can say is im glad you dont work for me
ive been fitting satellite dishes for over 25 years and not once have i laid coax in the gutter
koansrc
Athens-Greece
As for the actual thread, my 2 cents worth is this : 1) On large appartment blocks it is obligatory that there is one central aerial for TV and not a bunch of them 2) Dishes sticking out all over the place are ugly. Combining the two points, I think it might actually be a good idea to combine as many TVs onto as few dishes as possible, BUT with the owners consent and with the necessary safety precautions. Also new builds could cater for one single point of distribution of all "common" forms of broadcast with pre-installed wiring.
Cables in gutters ? Gutters that usually have moss and permanent moisture ? I guess it's perfect if you're looking for a quick and dirty solution .. .. .. you could even get entry into the house without drilling by coming up through the drains .. .. ..
