some888
- Apr 7, 2007
- Age
- 48
- relook mutant 200s
- england
hi guys!
please share your experience for the best LNB from your experience.
I'm trying to get Xtra TV form Amos and no luck so far.
My location is London
for the testing I'm usind TD 110 dish
but I've been able to get stable reception on quite many transponders so far
according to lyngsat I been able to get stable reception from the following beams:
_http://www.amos-spacecom.com/resources/flash/map/multiMap/map_amos2start.html Europe 05.5
_http://www.amos-spacecom.com/resources/flash/map/multiMap/map_amos3start.html Europe V 06.6
but what I still can not get is
_http://www.amos-spacecom.com/resources/flash/map/multiMap/map_amos3start.html Europe H06.5
that is a bit strange because coverage maps for European beams V and H are the same, only Europe 0 is different and has much stronger signal.
So far I managed to test following LNBs on the freq 10722 H 27500
I collected some LNBs I had I home and did simple testing.
here are some results
teste using sm-2500 meter
all LNBs are old and been in use and for some of them I just can not find model number.
*twin Bigsat 0.3 db / snr 69 - signal quality 45
*single wiztech 0.3db/ snr 67 - signal quality 44
*single Smart Titanium 0.1db( I think) / snr 72 - signal quality 54
* single MTI AP8-xt2ebl 0.2db / snr 70 - signal quality 47
from my experience MTI Highline was the best, but I do not have it at the moment. I ordered it already and will give you results soon
Please share your experience what I your best LNB for the fringe reception
in particular I'm interested in your feedback in
TECHNOMATE HIGH-GAIN GOLD series
INVERTO BLACK ULTRA HIGH-GAIN series
INVACOM TWIN UNIVERSAL 0.3dB LNB TWH-031 or same series
WS INTERNATIONAL VOLTAGE SWITCHING LNB OFFSET / Low Noise Figure: 0.2dB / 13K- High Gain Figure: 70dB
