BlindFaith
TBS 5925
1st real test carrier. Looks nice :D
BlindFaith
TBS 5925
BlindFaith
TBS 5925
next:
BlindFaith, where are you?
So the last carrier from you seems to be 20dB more than the previous ones you posted. Would you say that was a full power transmission, comparable to other PE beams? Or still weaker?
BlindFaith
TBS 5925
Off again. Apparently the high power mode lasts only for few minutes..
BlindFaith
TBS 5925
BlindFaith
TBS 5925
12324V still on
Maybe they don't even change the power but just transmit a very narrow band carrier ;)
welshman234
sky hd uk, 80cm kathrein dish,vu+ solo, humax f1 fox for hotbird 13
frankfurt
Blindfaith could you kindly tell us where in Europe you are to help us orientate ourselves when evaluating our own signals etc.
Cheers
BlindFaith
TBS 5925
have a look at the latest screen shots ;)
12325V powerful narrowband carrier here.
welshman234
frankfurt
Blindfaith thanks. I have relatives who live not too far from you. Looks like you are going to be in a good position for future 2F reception anyway. Thanks for your data ......
i receiver signal 12329 v 38%
need 3.5m
soon i upload screen photo
need 3.5m
Solly, what does that mean? Would you say it is UK beam as you were using a 1.2m dish for the transmission on 12185H?
Anyway at last I can see a transponder that is well above the noise floor. Was starting to worry for a while.
i not recive it now
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
First of all, when positioned on another position than intended the footprint will be different. I presume that on a position east of 28.2 the footprint will shift somewhat east as well. Furthermore when the signal can be received in Israel than I'm 99% sure that the Pan-European is being tested.
12324v i got 40%
i got first transponder 12237h 43%
DX Excalibur
3.0m PF dish C&Ku band 103E-40.5W/1.4m PF 75E-37.5W, DM 500HD,TBS 5925/6903
RO, near Bucharest
12226 H is active now with strong signal, similar to 12324 V witch is off now.
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
Ok, now it is good! There is a fairly strong test signal at 12228H now...
