Help for non techies re: lost 5,5usa,5*, 4HD Foretecstar Passion HD in France
hairybadger
Bricoleur
46.1N 6.4E
see sig
The 1 metre Gibertini XP Premium I use in my multi sat set up (and prior to that on my motor) is a really excellent, well engineered dish. I'd certainly recommend it...
Hmm that's on my shopping list, either that or the SE variant (if I can work out what the difference is....), although I think I'll have to order it from Germany.
XP Variant appears to be marketed as a premium quality dish in terms of construction, fittings and corrosion resistance
SE Variant seems to be a lower quality economy variant with less robust fittings etc.
hairybadger
Bricoleur
46.1N 6.4E
see sig
ah - interesting. Bfsat (one of my usual suppliers) lists the 85cm XP at 79EUR and the SE at 89EUR! There is the "L" as well, which I know is inferior.
Maybe I got it the wrong way round! (Working from failing memory)
hairybadger
Bricoleur
46.1N 6.4E
see sig
OK - from what I can work out from the Gibertini website (.it address but I can only seem to get it in German) the SE (I'm assuming this is the SERIE E) is a lightweight alternative ie weight has been reduced as much as possible. Thus it is more expensive, albeit less robust. According to the site it is only available in 40, 60, 65, 80, not 85, so now I'm even more lost... Either way it isn't available in 100 :)
Well the best of luck making that particular decision!
Marp
S/H 80cm dish + PSI LNB, 1 x Konig digital decoder. Acer laptop Win7 x64
Marseille, France
I came across this thread only recently.
I am in Marseille and also have lost the 5 group channels. I can live without them, but I was just wondering:
- how critical is the skew angle (I'm fairly sure it's right, but it may be worth a fiddle...)
- does an expensive dish and LNB really make a big difference? (I got my 80 cm second-hand and it seems no worse than any others - slighly elliptical in shape...)
I receive all the ITV, BBC C4 etc channels fine, even when it's raining. I lost Movies 4 Men and MoreMovies a while back too and couldn't get them back which was a pain. Horror Channel is still there though :)
Some people here in this area seem to be getting by with an 80 or 85, but are we all going to have to upgrade to Jodrell Bank size once this new 2E satellite I've been hearing about comes on stream?
Cheers.
PS: Bonne année and all that
hexah
Hadrians Wall
:-welcome1
If you are getting the other channels ok then the skew should be fine.
The rule with dishes is the bigger the better. You can fiddle about with the other components all you like but the bigger the dish the stronger the signal. I always recommend people go a size up for satellites that are their main viewing so they should never have interruptions.
I think they are somewhat weaker now. Perhaps some one can confirm as I am not sure of changes to that beam.
We will have to wait and see!
It is possible to get reasonably priced dishes up to 1.2m though hopefully it won't come to that.
sonnetpete
wordpress.com
Normandy, France
I'm getting all the 5 group of channels without a problem at the moment, up to 99% SNR. This is on an 88cm dish but with the LNB off focus as I use the dish with four additional LNB's to receive other satellites. I'd suggest that if your receiver has either a blind scan or network scan you use that or check on http://en.kingofsat.net/pos-28.2E.php for the frequencies your missing channels are now occupying and enter new transponders in your receiver.
I doubt that you'll have to go up as far as a 1.2m dish, even though you are at the other end of France from me
There were a lot of frequency changes last November when Sky took over many of Eutelsat's frequency allocations. So make sure your transponder lists are up to date
http://www.flysat.com/28east.php
Marp
Marseille, France
Great, thanks for all the info!
nebeluk
Fortecstar Passion HD 83cm Dish
Ste.Maxime, Var ,France
Hello, just got back from the UK, and have lost all BBC channels. The 5 bouquet are long time gone. Last night I was able to watch ITV3, but now today, almost everything has vanished; I seem to be left with a choice of the Food Channel or Sky News :-( I guess this is the end of Freesat as we know it here in southern France. Anyone got suggestions they would care to share?
Many thanks
Think you're going to have to go to a much larger dish if you can. Maybe 1.2m, 1.5m or something like that.
nebeluk
Thanks for that Paul, but I am limited with what I can have as I have an apartment in a co-prop. Just a thought; would I be able to get Sky with the dish I have? I have friends in Spain (Alicante) and they have no problem with their service on Sky .
Yes, that's a problem for a lot of people. Some are able to negotiate access to the roof, if it's flat, and put a large dish there.
Yes, absolutely. You'll need your address in the UK and Sky receiver of some kind. Maybe you already have one in UK? You could take it out and back with you as I do with my Foxsat HDR.
