mehra
SATELLITE SNIFFER
- Oct 23, 2006
- Age
- 51
- 2 Dish Tv Zenega STBs | 1 DM 800 HD Clone | 180 cm TX Rx Fibre offset Dish Antenna |
- india
Dear friends I am using a Conax card in which some channels are detected as DC and some Seca encrypted, however its a fake detection and actually its conax. But emulators get confused and channel is not decoded. Conax ones are ok on same emu.
Mgcamd solved the problem if provided with a replace.list for the caids that are detected as seca or DC.
My setup : DM 800HD
Oscam reads local card.
Mgcamd connects OScam to decode channels.
The problem :
MGcamd is sure to crash on some selected channels (well they are mostly conax ones). Restarting the emu (Mgamd) is the only solution then.
Thus I wish someone helps me to connect OScam as CS + some other emu that can handle the said fake encryption (seca and DC). Maybe GBox can help. Please note that my card is paired one.
Thanx in advance !
My setup : DM 800HD
The problem :
Thanx in advance !
