nadal liu
- Jan 16, 2014
120cm offset dishes for 124e and 128e with emp centauri profi multiswitch 9x16, and 5x20
,180cm prime dish with lo 10678 ku lnb for 110e bs/cs
- Hong Kong
I ordered an emp centauri powerline 5 x 20 multiswitch.
It is in transit.
I want to make sure it will work with my set up.
I want to receive 124e and 128e, both have two polarities and in hi band only.
I want to use two two-output single local oscillator lnbf.
I will connect the two output from each lnbf to the four input on the multiswitch.
Will it work?
I am afraid because the four input are hi/lo x h/v.
With lo 22k off, can I receive hi band signal?
Thanks.
It is in transit.
Will it work?
Thanks.
