IRIB 20E
remlap
Wales
Just for the first time caught IRIB mux on 20E always been a distant possibility for me due to being DVB-S2 8PSK I think it may of changed?
3964 R 30000
Can't confirm 2/3 or if DVB-S2 8PSK would anyone able to help me out?
remlap
Wales
Anyone able to give it a look?
If the weather is ok over the weekend I'll try and take a look, although it means pulling the 16E / 21.5E & 26E lnb's off one of the 1m dishes!
About time I had another look at 20E anyway
:D
nelson_b
Contributor
3964 R 30000
hi remlap - i,ve only just seen this thread --
i just re scanned this with the F15 and it shows as 3/4 DVB-S2 8PSK
regards ---
remlap
Wales
Brilliant thanks very much for looking. Notice any signal increase?
remlap
Wales
:D
Signal is very low here so might not be worth the effort.
nelson_b
Contributor
to be honest its so long since i looked here -- i cant say if its increased or not for me,
i,m using the 1.8 so i,m getting a strong signal -- its showing 11.2 db on the F15
cheers ---
remlap
Wales
Great I appreciate you looking.
Camgah
1.2m Dish Eutelsat 7E, Hotbird 13E, Astra 19.2E
0.6m Dish Sky UK 28.2E
Vu+ Duo2 & Vu+ Solo2
London
I'm very interested to get IRIB signal in London, would you please kindly help me about the equipment I need, i.e size of dish or ... as you already managed to get this.
your help is very appreciated.
nelson_b
Contributor
hi-- i,m using a 1.8 offset dish with a BSC421 ln.b. fitted with a conical feed for receiving C band channels -- but 20 east is generally much stronger than most C band transmissions so should be receivable with smaller dishes a 1.2 metre dish may well be enough to get the channels you want . i dont have C band setup on 1.2 here right now so cant check -- but i,m sure someone else on here can ??
regards -----
I used to see 20E on the 1.2m dish. Now, most transponders are below lock due to the house in the way and shadowing about half of the dish.
remlap
Wales
regards -----
It's 8PSK DVB-S2 so much harder a catch than the other signals there on my 1.2m
Camgah
London
So according to the feedback I'm getting I can get the signal for IRIB on 20E Arabsat 5C if I have the 1.8m prime focus c-band dish at London. Is this something for certain?
On the other hand can anyone suggest which piece of equipment and recommend me a place to get these staff? i.e the
-Satellite Dish
- Mount
- Type of LNB
- or ...
Imprtant questions before you start
do you know just how big a 1.8m dish is??
do you have tolerant neighbours & be willing to dig a big hole to contain several tons of concrete in it in the garden?
And do battle with Planning Officers.
Oh yes - you will DEFINITELY need planning permission!
Camgah
London
I don't think 1.8m is that huge.
Anyway I have a large private garden that I can place this over there.
For now lets think there is no problem with neighbours and no planning is required.
is this something that will certainly technically work?
You might not think its big but I guarantee you neighbours will :D
Camgah
London
Well I have a fully detached house, which there are no neighbours within 20m from the house.
remlap
Wales
What's the need for IRIB's channels?
