Astra 2E at 28.2E: General Discussion Part 1
Red is what was stated in original.
They are just theoretical maps with theoretical reception, based on when 2E and 2F were constructed as theoretical identical twins with more or less the same uk spot and ( pan ) european beams but with different TP capabilities.
Cannot believe the two sats will have the same highs and nulls for fringe reception on the ( theoretical ) uk spot beams.
Might be wrong but time will tell, bring on the PSB channel transfers:D
Agreed. The gradients of nulls and side-lobes are by their very nature immensely steep leading to highly localised effects on the ground. Most unlikely 2E's will coincide with 2F's.
anthony21
Wave Frontier T90---1W-42E
Northwest of Greece
11719H - 5.9 dB
11739V - 6.7 dB
11758H - 5.9 dB
11778V - 6.4 dB
11797H - 6.3 dB
11836H - 6.5 dB
11856V - 6.8 dB
11914H - 6.2 dB
11934V - 5.8 dB
12012V - 6.2 dB
12343H - 6.8 dB
12382H - 7.4 dB
12460H - 7.3 dB
Wave Frontier T90---1W-42E. LNB for 28.2=MTI White
It is a big surprise that we can receive Paneuropean beam of Astra 2E in my area, while for Astra 2F is necessary a satellite dish above the 2m for reception of Paneuropean beam of Astra 2F.
dvdfilm
1.5m dish
spain
That means 2E is not identical to 2F.
Possibly a shift to the right of the European beam compared with 2F?
So, any thought on if ITV C4s also move on Thursday also? Or on another day?
I cannot remember if they did from 2d to 1n....
BBC moved 7 days after the rest. Sunday 25/02/2012.
Not necessarily, in the context of the side-lobes and nulls: Even if they were identical in every way, the exact positioning and attitude of the craft can change where those nulls and side-lobes transpose to the earth's surface - And markedly so.
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
How long has 10847V BBC HD transponder had symbol rate 23000 ? As just now I had to change that symbol rate from 22000 to 23000 and rescan to get those channels viewed again.
skomedal
This and that
thule
Dont speak to early, they ( SES ) have not started tweaking/finetuning signal transmition/reception yet!
wolzy67
bigsat 60cm bigsat fta. Hispasat
1.4 p/f quad invacom. Astra 28
80cm offset nilesat
Gi genuis,gi 8120,gi genius on open atv ,en2
torreiveija Spain
Hi popolon had some old print outs of lyngsat ,10847v s/r 23000 since before summer last year.
Salva
DM800S and Tecatel 1.2 Offset
Gandía (SPAIN)
Even identical twins have their own foibles ( idiosyncrasies)
Now, correct me if I am wrong, PE 2E and 2F footprints are slightly different 2f covers Madeira at the expense of larger size on Canary Islands while 2E does not cover Madeira but has a higher eirp in Canary Islands. On the other side Astra 2E has a higher eirp in Poland than 2F that has a more uniform power over the east european side.
Whether this is due to different dish construction, feedhorn arrangement or just SES drawing trickery remains to be seen. My money is in that the UK footprints are going to be identical hence the sidelobes, I am holding to that by now, I have been on the lucky side of 2F, it is only a couple of days to discover all the truth!!, unless ses activates other UK spot from 2E sooner.
wolzy67
80cm offset nilesat
torreiveija Spain
Def some activity bbc no signal for a moment then back on
Hmm. They won't try anything significant during peak viewing!
Edit: Not intentionally, anyway! (Says he, having read the next few Posts)
cazhh
Elmshorn, Schleswig-Holstein
Which channel ? There was a megawobble event earlier this evening on 2F:
wolzy67
80cm offset nilesat
torreiveija Spain
I'm on fringe it was same last night roughly same time on itv pic pixelated then no signal approx 20 to 30 secs, 8.30 ish here
Possible ses fine tuning effect fringe ?
Never normally no problems.
11719H - 5.9 dB
11739V - 6.7 dB
11758H - 5.9 dB
11778V - 6.4 dB
11797H - 6.3 dB
11836H - 6.5 dB
11856V - 6.8 dB
11914H - 6.2 dB
11934V - 5.8 dB
12012V - 6.2 dB
12343H - 6.8 dB
12382H - 7.4 dB
12460H - 7.3 dB
the signal stable or change betwin day and evening ?
wolzy67
80cm offset nilesat
torreiveija Spain
Hi i was watching bbc1 don't know what transponder. Bang on 8.30 here though same as last night.
Quite few people noticed it here.
wolzy67
80cm offset nilesat
torreiveija Spain
No rock solid even on 2 f day night.
Just thought some must be going on
skomedal
This and that
thule
AFAIK no uk PSB channels have been tranfered yet!
tothbros
Budapest, Hungary
the same thing happened this afternoon on channel 5 hd...i had it in the background when i noticed pixelation, then no signal, few seconds, and then back to normal. this tp is not on the edge here by any means.
