Advice Needed Would I really notice a difference with a new LNB ?
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I presume my existing 8 yr old LNB is about 0.7db not too sure, would a new inverto ultra etc really make such a difference ? Also why is a quad version better than a single one btw ?
Finally is changing the sat coax worth it or not ?
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
it can make the difference between getting a lock on a fringe signal... its up to you as its your system and you know if you are happy with how it performs
An 8 year LNB will be an old generation one, on which the oscillator is probably past it... which means that there will be a shift in frequencies received and weaker signal.
Yes, a new Black Ultra WILL make a difference over such an old LNB. In fact, it will outperform most LNBs currently on the market, so it's a wise (and cheap) investment.
No logical reason as to why a quad seems to be slightly better than a single one. I haven't really noticed too much difference to be honest.
And, yes, change the coax - it's probably been damaged by the elements over time with split outer sheath, letting water in etc...
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Ok thanks fot replies, I see there is an Inverto quad and Quattro btw, what is the difference apart from the former being £6 more ?
You want quad - each output is independent from the other and will provide you with horizontal-low/high and vertical-low/high bands for up to 4 receivers.
The quattro will have only one of four bands available on each of its outputs - HL, HH, VL, VH. It's usually used in blocks of flats where feeds are distributed via a special switch to receivers.
Quattros are purpose designed for use with Multi-Switches: The four outputs are Vertical Low, Vertical High, Horizontal Low and Horizontal High whereas a Quad has four independent outputs than can be switched directly by the Receiver to select any of the four flavours of signal.
Edit: Sorry, CJ. Failed to check for other replies!
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
OK thanks, have just bought one
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Just received it, what a lovely box also ;-)
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
So you've already discovered a hard to get erotic channel........
Hmm I have no idea what you mean ! I only said I received it, not fitted yet or perhaps I should say.. it's not up yet ?!
