TurkSat 4A is testing @ 50 east
Turksat 4A will be operated at first at 50 degrees east longitude before being moved to its permanent slot at 42 degrees east in a few months time.
Test carriers observed so far:-
http://www.flysat.com/turksat4a.php
New test carriers observed 10 min ago,
Turksat 4A @ 50 east
Test Carriers:-
11644 H
11708 H
I remember seeing Anatolia 1 testing at 50E about 10 years ago The region was shut down for nearly a week due to very heavy snowfalls so I used the time to do some satellite dxing using the 60cm dish
Analogue colour bars found :D
Test Carriers:-
11644 H
11708 H
There are no test carrier of Turksat 4A ...
11644 H comes from near Eutelsat 48D/Afghansat 1 and 11708 H from Galaxy 26.
No need for a mount - I just propped the dish up in two feet of snow :-rofl2 :-lmao
Two test/promo transponders were activated in both polarities-H/V:12246 MHz H pol & 12303 MHz V pol:
it look soon end of testing
Turksat promo at 11665 V,2221,3/4 is back on Intelsat 5-50.1E;weak signal!
Archived-1
Persona non grata
uk
I am only getting 12303 V 27500 here at the moment, strong signal on my 1.2, I am sure the 1mtr will catch it.
pride21
Sandown Isle of Wight
P4050009.jpg hi martin I can only get transponder 12246H
Archived-1
Persona non grata
uk
Hi pride, your screen grab shows 12303 ?.
pride21
yes you are right martin its 12246H that I could not pick up,cheers
adonis1
Turksat 4A Teletext
12246 H 27500 14.9 db
12303 V 27500 18.0 db .
martin-f said:
...maybe two different beam's are you are near both footprints ?
This is how the satellite footprint on different areas:
tempo
47.5N, 42.2E / Russia
Reception of both TPs on 0.9m dish in my location.
adonis1
Laser
12303 Vertical 27500 coming in here in South of UK with 97% SQ
With the 1.2m dish
