Alibi HD & Dave HD move?
tothbros
Budapest, Hungary
unless its some technical issue (which i doubt), it seems Alibi HD and Dave HD moved to a UK beam, because i'm getting "no signal" on both.
E! HD, which is on the same tp works normally.
Retired Mod
www.timo.me.uk
I think they have both moved to 10936V.
tothbros
Budapest, Hungary
well, thats mighty disappointing...:mad:
Retired Mod
www.timo.me.uk
Yes, it would appear Sky are keeping hold of their 5 or so UK spot transponders.
Tururu
Assembled with recycled parts
Recycled as the owner.
Cambiaron.
Ayer actualizando la lista de canales y hacen el cambio hoy.
PD: :-doh
Changed.
Yesterday updating the list of channels and make the change today.
PD: :-lol
Niveles por Madrid (Spain), cerca de IKEA/Levels for Madrid (Spain), near IKEA.
10935 =2E 9.50dB Señal/SNR 59% AGC99% BER 0
12382 =2E 19.50dB Señal/SNR100% AGC99% BER 0
How did you do this comparison - what program?
Tururu
Receptor linux, despues de lanzar una busqueda de todos los tp's uso DreamBoxEdit/Dreamset para comparar y ver cambios.
Receiver linux, after launching a search for all tp's use DreamBoxEdit / Dreamset to compare and view changes.
DreamBoxEdit.
El resultado lo muestra en otra ventana/The result shown in another window.
diferencia_26_3_2014-jpg.63593
DreamSet
Aparte del satelite a 28,2ºEste general, tengo creado otro a 28,3ºeste con todos los tp's añadidos con notepad++/Apart from the satellite at 28.2 ° East generally, I have created another 28.3 º east with all tp's added with notepad + +.
De esta forma controlo mejor los cambios/This way I control the changes better.
Tururu
Mas cambios hoy/But changes today.??
ID 10265 ==> update ==> ITV4 Plus.
12246 delete, change??
diferencia_26_3_2014_16_41-jpg.63595
Tururu
12246V is still there with the same channels.
En este tp nada de nada, ayer sin problemas cuando lo sintonice, revisado el resto de tp's que tengo....OK, en este no tengo nada de señal por Madrid (spain), continuare revisando, es raro.
This zilch tp yesterday without problems when tuning, revised other tp's I have .... OK, I have nothing on this signal by Madrid (spain), I will continue reviewing, is rare.
Tururu
ITV4Plus is almost certainly just a holding channel for one of the new ITV channel launches. It carries ITV4 +1 and is only active for a couple of hours in the early morning. 2 hours a day being the minimum Sky require to keep an epg slot active.
Retired Mod
www.timo.me.uk
Ahora tengo señal, baja (6.00dB Señal/SNR37% AGC99% BER 0), pero tengo señal, el resto de tp como siempre.
Now I signal, low signal (6.00dB Señal/SNR37% AGC99% BER 0) but I have the rest of tp as ever.
La relacion de tp revisados es la misma de este post.
The revised relationship tp is the same in this post.
http://www.satellites.co.uk/forums/...-balearics-reports.159949/page-25#post-880306
28e_12246v29500_26_3_2014a-jpg.63605
Could it be Badr interference?? There is a transmission on 12245V according to Lyngsat. Odd though, can't see why it would be so bad on one frequency all of a sudden.
Tururu
Problema mio.
Con lluvia los niveles de señal son bajos (-6%).
Los canales del Astra2F y 2E tienen mejor señal.
Los canales del haz norte 28A para Europa tienen peores niveles.
Los niveles en 12246 V 29500 3/4, son mas bajos, por Madrid (Spain).
Necesitaria 180cm de antena con mal tiempo, como ahora.
Mirando con el analizador de espectro en 12246.
Buen tiempo, perfecto con 76dBµV.
Lluvia ligera, regular, muy pixelado 75dBµV.
Lluvia muy fuerte, mal, nada de nada. menor que < 74dBµV.
Tema interferencia con Badr26E....12245 V 27500 5/6.???
En condiciones normales (buen tiempo) no afecta.
12246 = 6.00dB Señal/SNR37% AGC99% BER 0
Instale 3 sintonizadores, 1 para mover el motor y 2 para ver la señal en los tp's de AStra28E y de Badr26, mirando las señales en el analizador de espectro.
Si muevo 0.3ºal Oeste, pierdo señal de 28E.
Necesito mover 0.5º mas al Oeste para empezar a tener señal de 26E.
Necesito mover 1.0º mas al Oeste, para tener señal 100% de 26ºEste.
Antena orientada a 26.4ºEste aproximadamente.
El ancho del tp cambia de 27.500 a 29.500, no se ve muy bien en las fotos, lo siento.
Con lluvia fuerte, en 12246 no tengo señal y en muchos mas tp's (sabado 29 17:00-20:00).
Los niveles son:
4.00dB Señal/SNR25% AGC99% BER312.
Incluso 21% y por debajo de este valor, el sintonizador ya marca 0 al tener muy poca señal (DVB-S2)
Astra28E...12246 V 29500 3/4, ===> Badr26E....12245 V 27500 5/6
Astra28E...12168 V 29500 3/4, ===> Badr26E....12169 V 20200 3/4
Normalmente el cambio es rapido, de tener señal a no tener señal, pero el otro dia se quedo en un punto intermedio y solo perdi la señal en 12246 durante horas.
El domingo por tarde-noche, el cambio fue mas rapido, repitiendo segun condiciones meteorologicas en bucle.
Lluvia suave...todos bien.
Lluvia moderada..los 2 tp's mal, resto Astra 2F y 2E bien (-6% menos)
Lluvia fuerte... todos los debiles pixelando o sin señal.
PD: Por Madrid (Spain), minimo 150cm para no tener problemas, mejor 180cm.
My problem.
With rain the signal levels are low ( 6%) .
Astra2F channels and 2E have better signal.
The north beam channels 28A for Europe have worse levels.
Levels in 12246 V 29500 3/4, are lower for Madrid ( Spain ) .
180cm antenna would need in bad weather , like now.
Looking to the spectrum analyzer 12246 .
Cloudy , with 76dBμV perfect .
Heavy rain , regular, very pixelated 75dBμV .
Very heavy rain , bad , no nothing . less than < 74dBμV .
Thread interference with Badr26E .... 12245 V 27500 5/6. ? ?
Under normal conditions ( good weather) does not affect.
12246 = 6.00dB Señal/SNR37 AGC99 % BER 0 %
Install three tuners , 1 for moving the motor and 2 for the signal in the tp 's of AStra28E and Badr26 , watching the signals in the spectrum analyzer.
If I move to 0.3 º West, I lose signal 28E.
I need to move more 0.5 º west to start having signal 26E.
I need to move 1.0 ° more to the West, to have 100% signal 26 ° East.
Antenna oriented approximately 26.4 ° East.
The width of tp changes 27500-29500, does not look very good in the pictures, sorry.
With heavy rain, I have no signal and many more 12246 tp 's (saturday 29 17:00 to 20:00 ) .
The levels are:
4.00dB Señal/SNR25 % AGC99 % BER312 .
Even 21% below this value , the tuner dials 0 and having very little signal (DVB -S2).
Astra28E ... 12246 V 29500 3/4, === > Badr26E .... 12245 V 27500 5/6
Astra28E ... V 29500 12168 3/4 , === > Badr26E .... V 20200 12169 3/4
Usually the change is rapid, have not have signal sign , but the other day was left in between and only lost signal in 12246 for hours.
On Sunday evening, the change was faster , repeating loop according to weather conditions .
Gentle rain ... all good.
Moderate rain .. 2 tp 's wrong, rest Astra 2F and 2E well (-6 % off)
Heavy Rain ... all pixelando weak or no signal.
PS: Madrid (Spain), minimum 150cm to avoid problems, best 180cm.
