- Aug 10, 2008
- Romania
Best LNB for offset dish is Inverto Black Ultra,except those professional,which most users know.What if this offset lnb could be used for the antenna Prima Focus if we could mount some scalar rings on it?, but most importantly, with what results?
Here with the help of conical scalar ring for LNB , 4 Rings ,mounted on Inverto Black Ultra ,I managed to achieve exceptional results .I did a comparison between Inverto Flange for antenna PF and Inverto Black Ultra for antenna offset, now used for the first antenna.It is a cheap solution when the signal is weak or at the limit:
As an important detail, with this combination{offset Inverto Black with conical scalar ring} I managed to receive a transponder from the Astra's UK spot:10906 V with 1.5 m dish!
ILNB Inverto flansa vs Inverto Black Ultra on 10906 V.jpg236.8 KB · Views: 616
