zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
- Malta
yes indeed.. According to crazyscan the mux is signalled as ACM/MIS (only a one input stream active). If you check the mux with TSReader the mux rate is 28,5Mbps whereas a carrier with 45000MS, 8PSK, 2/3 yields 54Mbps. No problem with TBS5/6925 but how is that possible with a DB8000?
So further to this enigma...In my dreambox 8000 I have four Tuners....2 on board and two plug ins.... With the plug-ins I have an ALPS REV M and the other is a BCM4505 (just like the one I have in my in a DB 800se). Now with the ALPS Rec M I have a 1.2 Dish connected and with that configuration I can get these MBC channels whilst with the BCM 4505 and a 1.5M Dish configuration I CANNOT (always with DB 8000. ) Now with my other Dreambox DB 800se incorporating a BCM 4505 Tuner and a 1.2 Dish I again am drawing a zero on these channels. Both 1.2 Dishes and the 1.5 m are of a Gibertini make and all of them have a Black Ultra LNB.
Now also I happen to know that MBrincat Tuner is an ALPS Rev M in a DB 800 HD.
So the Tuner is the common denominator .
