TurkSat 4A is testing @ 50 east
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
As my last defiant act before deferring to the Sandman, I've trimmed Az a long way either way and there isn't a sniff.
So as the Frequencies are similar, SR is correct, Polarities are both V, then the suspects are Interference or one of those inexplicable LNB incompatibilities.
But that really is my lot for tonight - the old eyelids are attempting to travel south.
PS VS: I hope you meant 12377, not 12733 .................... !!
Yep Typo buddy
I'll fix it now I can
Archived-1
Persona non grata
uk
Very annoying.I am still getting nothing on this.It must have gone back behind the tree.
My friends Dishpointer app shows it just on the edge of a large conifer.
Just get a laser pointer ponti, and check at night, but I would guess your correct with the tree,
This is the one I use, the cheaper ones from maplin are rubbish, but this one at £9.99 is fine.
http://www.maplin.co.uk/p/keychain-laser-pointer-l99ac
pontiend
Contibruter
south yorkshire
Taking the grandkids there in the morning.Will have a look.:)
If anything the signals are a few % stronger than earlier on both freqs..
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Had a shot at 50E and these two Freqs came in 12377 V & 12343 V. The Latter is slightly weaker by about 1db. Dish in use 1.2.
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
2 new txp,s today
11.891.V.20000
11.918.V.25000
Got 11891, not 11918.
Same pattern of inconsistency as yesterday >>> so I've been out and looked along LoS and discovered that the brutal and decisive removal of several occluding Pine Trees was not sufficient and that the outer branches of next door's Pear Tree are infringing.
And I suspect there's nothing (legal) I can do about that.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Yes no modulation though
BlindFaith
TBS 5925
I think it's more your location.
pontiend
Contibruter
south yorkshire
2 new txp,s today
11.891.V.20000
11.918.V.25000
Thanks for that. I got nothing at first.I lowered the elivation a little and got both of them.
11891V 78%
11918V 70%.
I though that I had lost this satellite behind a tree.Obviously not.
11891 certainly was modulated, showing the Channel Tanitim-2.
But no doubt these things change from time to time, it being Testing.
Yesterdays 2 tps - no signal.
No probs here with todays freqs - 11891 is carrying Tanitim2, 11919 is carrying Tanitim3
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Yeah have them ok now.
This morning's haul:
11893 V 20000 Tanitim2
11920 V 25000 Tanitim3
So, not much change - apart from the fact I can now get both of them, unlike before. Not got to the bottom of that yet.
Archived-1
Persona non grata
uk
The skybox does strange things Tivu, it brings in teletext here as I mentioned in an earlier post , I have just been checking on another box no teletext, on certain transponders the skybox will have the signal level dancing around, check with another box solid signal,
It will also nearly decode certain multi stream TP, its a strange box and always worth trying another STB if you feel you should be able to get a certain TP, that's presuming you are using the skybox :).
mar-val
Slovakia,Zilina
This morning I locked 12343H. Very weak on 220 dish.
What screenshot is that signal meter from, mar-val?
Archive-8
Does that mean the eutalsat ka band lnb will pick up the beams?
