Amos 3 4.0w European Beam
XeonSX
1.1 Motorised Dish & multifeed 1m dish
London
What dish size would I need to pick this up? I'm in London.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hello
Welcome to the forum XeonSX
Well big would be the word that springs to mind
see the footprint on this non active link
-http://www.amos-spacecom.com/resources/flash/map/multiMap/map_amos3start.html
I am sure someone nearer to you than I am will give you an idea of size
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Hi, Which channels/transponders are you after? I can get quite a few of them about 20 miles east of you. Not brilliant signal, but good enough on my TD110 ( 1m) for some.
If you tell me what TPs, I'll check them one by one, too many to go through otherwise.
One of the weaker channels that I can pick up below, Enter film, has occasional popping and squeeking.
XeonSX
London
Thanks for answers, I am actually trying to pick up 11389H that Enter Film is on. Unfortunately I cannot pick up any from that beam, also on 1m. Would you say with confidence that 1.5M dish will be able to pick this up?
Thanks again.
Thanks again.
Impossible to say as strange things start happening with extreme fringe reception. Reception can vary wildly over a few miles. Unfortunately the only way to find out is to be prepared to try a few dishes of increasing size.
NukePower
Bush HD freesat & 2 modified 2nd hand Technomate boxes. 43 & 1000cm dishes, selection of lnb's & couple of motor. Desktop computer, windows XP home. BT slowband. Used (£7) digital camera from charity shop.
sizewell suffolk
9 fta channels and 1 encrypted on that transponder received on suffolk coast. picture and sound gets blocky during rain, 1m dish.
NP
Archived-1
Persona non grata
uk
Hi, I know this is an old thread, but i am getting a lock on this, very weak but locked, conditions are not the best and I think I will be able to get a clear picture once conditions improve,
This is only the transponder I have had a go for, I will open a thread for this in fringe after further test :).
1.2 CM dish skybox f3s.
Piltdownpaul
No.1 Spike Milligan Fan
Tricky marginal reception here on my TD88. Any serious cloud is enough to lose signals, today i'm getting MusicBox on 10806H 30000 and thats only just locking.
nelson_b
Contributor
Same for me at this location -- with same dish /receiver setup -- got a clear picture for a while -- but pixelated now the cloud is back .
no lock on music box t.p. though just now --" Piltdownpaul " although i,v had it ok in the past -----
Archived-1
Persona non grata
uk
The V transponders are strong here, I have just gone through all Amos 3 transponders and getting 163 TV channels.
Archived-1
Persona non grata
uk
10806 H 30000 is Amos 2 is it not Paul ?.
Piltdownpaul
On lyngsat listed as Amos 2/3 so i dont know without further investigation on my behalf. I was just chuffed i got anything from either.
Piltdownpaul
I use all three, Kos, Lyng and fly but i came to fly last and consequently dont use it so much.
Archived-1
Persona non grata
uk
Yes I do Paul, Kos is great for zapping channels when I have no idea what satellite I am on, when moving in between tight together satellites.
BlindFaith
TBS 5925
..little more to the east it's ok with 120cm ;)
Amos is a pita to receive. I get some channels with good lock margin, mainly on Amos 2 but 3 is more difficult. I find that 3's signals vary a lot... Sometimes I can see 11222, 11258, 11336 and 11389 on my Fibo with no problems but most of the time they are below lock. The 1.5m Gibby gets 11389 and 11258 most of the time but it's right on the edge. 11336 and 11222 are locking but not watchable.
I find the most stable TPs on 4w to be 10729h and 10759h which are all doable on a 1.2m dish all the time with some small rain margin...but not much.
Archived-1
Persona non grata
uk
I've Never really had a play here, what an interesting satellite, I am probably also pulling 5W in from a blind scan. but a good place to monitor.
Yes will be interesting to ser what you get from it on the 1.8m...
Archived-1
Persona non grata
uk
Yes CJ, I don't know where to start TBH, I will have a few unknown avenues to discover from 61 W/ 57 E, then all C band c/l plus extras what the 1.2 cant do, fringe on the 1.8 is going to be exciting
