Setting up Sky Freesat in Communal setup
maltesedog
Communal
Dundee
I am looking to set up Sky Freesat. There is a Communal satellite already in the block of flats I am residing.
In this respect, Sky are providing little assistance, and referred me to a company called Campbell and Kennedy, who informed me that they no longer to freesat by Sky.
However, I am still interesting in the benefits of setting up Freesat by Sky, and I'm looking for suggestions on the way forward.
I am understanding that if I buy a Sky setup box, a satellite connection cable, and the Sky freesat card standalone £25.00 this should work. Am I correct? The satellite is already in place, and is communal in the building I am renting.
Any suggestions on which box I should buy and how to go about setting up this?
Your help is greatly appreciated.
You dont get much choice of Sky receivers these days. The HD box is the standard box, its more which hard drive size you want.
Do you want recording facility? If so you would be better off getting a Freesat receiver.
maltesedog
Communal
Dundee
I'm not after a normal Freesat box, reason being I am a BTSport subscriber, and BT offers free BTSport on the tv for people having the Sky connectivity. I am not interested in recording.
Fair enough.
In that case box, card, and connect it all yup and away you go. :)
maltesedog
Communal
Dundee
Fair enough.
The problem now is which box, there are plenty of boxes on Ebay, some of which are 'fake'. I saw one on Amazon, but the seller would not guarantee that the setup I am suggesting would work. Keep in mind there is a communal sky dish in the building.
I greatly appreciate your help as its my first time dealing with Satellite TV.
As long as the cabling from the dish to your apartment is ok there is absolutely no reason why it wouldnt work.
Stay away from any Grundig, or elderly Pace boxes - they have power supply issues.
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
If you're not bothered about HD, you could try to get hold of a Panasonic box. TU-DSB30 is the one I had if I remember right! :)
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
maltesedog
Communal
Dundee
There is no such thing as Fake Sky boxes , there are FTA satellite receivers and official SKY boxes , make sure you ask that a Sky card will work with the Sky box and you will get the right one , i suggest a Sky + HD , maybe one day you want to record something .
http://www.ebay.co.uk/itm/DRX890-50...on_Satellite_TV_Receivers&hash=item338cfd3b1d
Thanks for this, so basically you're saying that any Sky Plus box would work with a Satfree Sky card, connected to a communal system. Am I correct? I quite like this Amstrad DRX890 you are suggesting.
All I need is the box, a cable, and the £25 card given there is already the communal satellite?
You won't get Sky Plus Recording enabled with a £25 FreesatfromSky Card ................. I think they charge ten pounds per month for the privilege of actually being able to use the box properly.
Edit: sort of reinforces what marius said (Sorry, failed to read in detail!)
maltesedog
Communal
Dundee
As I'm said I'm not interested in recording. I just want to confirm that it works before investing in the box and the card!
smoggy07
Yes a Sky+ box will work with a Free Sat From Sky card with your communal system.
If BT will activate their channels on a FSFS card, any bog standard Sky+ box will do the job, the communal system will morethan likely be for UK Sky on the Astra 2 satellites at 28.2E and Hotbird at 13E (or UK Sky and 19.2E Astra 1 satellites)
Do you know anyone with Sky (or an old Sky box) who could call round and try their Sky receiver at your place for 5 minutes?
maltesedog
Communal
Dundee
Unfortunately, I've just moved to this place and I don't know anyone. To make matters worse, I won't be moving the tv until the 26th May, and so I'm preparing everything for the move beforehand. I've been told by the landlord that the satellite is for Sky. BT can activate the channels on a Sky card (see https://community.bt.com/t5/BT-Sport/BT-Sport-and-my-Freesat-set-up/td-p/987194)
smoggy07
So all you need then is a Sky+ box, the card from sky and the cables to connect it all up then and you're in business
mariust5
hastings , uk
Ok , i have been giving people white sky cards so they can activate BT Sport on them , it worked a while ago , so it doesn't need to be an expensive card , you can sometimes buy the box with the card , have a look on ebay close to you and ask a question or go to a boot sale .
And if i'm not mistaken if you activate BT on the card the recording facilities will also work but don't quote me on that .
Get a Sky+ HD box as it's more future proof than the others . Make sure you get the smaller size box as that is newer and looks better .
mariust5
hastings , uk
If that makes you happy go for it , i was giving you advice on how to get one for free or next to nothing .
maltesedog
Communal
Dundee
Obviously I appreciate but I know nothing about this. How do you obtain it? Will that give you the free sat channels anyway?
mariust5
hastings , uk
maltesedog
Communal
Dundee
So I'll get sat free as well automatically with this card?
