New BBC TP - 11464H 22000 5/6
M60
Northern England
This turned up yesterday or possibly before the weekend, has one SID labelled 'BBC Commenwealth' showing colour bars and tone.
C/N here in the UK looks very good, can a few people give reports of this abroad as it is possibly on the UK spot antenna either from 2E or 2F. If so, is it the first TP using SES craft to be illuminated by Eutelsat as it's in the previous Eutelsat sub-band?
Retired Mod
www.timo.me.uk
There were data transmissions in this band before 1N left which may have been from an Astra satellite.
tothbros
Budapest, Hungary
on this freq at my location, using a sky box, there is "no signal" - must be a UK beam...which is strange to see a spot beam tp in this range.
Pietclock
125cm
SE Germany 50°N/11°E
yeah, this is on UK beam, 9dB SNR here like 2F UK TPs.
Program Number: 1
PCR on PID 33 (0x0021)
PMT Version: 3
Service name: BBC Commonwealth
Stream Type: 0x02 MPEG-2 Video
Elementary Stream PID 33 (0x0021)
Stream Type: 0x03 MPEG-1 Audio
Elementary Stream PID 34 (0x0022)
Descriptor: System Clock Descriptor
External Clock Reference: 0 Clock Accuracy Integer: 2 Exponent: 1
Descriptor: Maximum Bitrate Descriptor
Maximum bitrate: 25000000 bytes per second
Descriptor: Smoothing Buffer Descriptor
SB Leak Rate: 625 SB Size: 1024
Obviously not meant for BSkyB or Freesat Boxes:
Channel 1
On Table_ID: 0x42 (current mux)
Service Name: BBC Commonwealth
Provider Name: Globecast UK
Transport Stream ID: 1 (0x0001)
Seems to be a feed.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Obviously prepping for the Commonwealth Games 2014 in Scotland.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
Receiving here OK.
RichardinSpain
Totana, Murcia
Dreambox 500s motsat3 motor
Totana Murcia Spain
Coming through here in Spain ok too
M60
Northern England
Cheers for your feedback folks. Fringe, how is this TP coming in compared to what you receive 2E/F C & D band-wise over in Tenerife?
Interesting the provider is Globecast too, I reckon this could be for SNG use or that the BBC have struck a deal with Globecast for cheaper carriage - rather than using ATOS who are their de-facto uplink provider.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
When I checked earlier it was 67% quality on my TM F3/5. That's about as good as it gets for me on a UK spot.
M60
Northern England
Cheers, was curious to see if there was a difference between the C/D band TP's and this, with this being higher up the spectrum a tad.
It means that if Eutelsat want to, they'll probably have a combination of spot and PE TP's once they begin their agreement with SES.
mickwig
90cm Astra1 dish;
As I wrote earlier this year according to SES any TP on the new sats will be able to use any band on any beam available. Which makes sense if you want to be flexible with backups etc.
Pietclock
125cm
This transponder is carrying several BBC Red Button channels now. Both SD and HD, on one currently BBC Three HD is running.
Very weak here with 1.25m - 7dB SNR. But both 2E and 2F are very weak now, probably only getting better in August.
Blasting in here - deffo one of the spotbeams. The signal meters are hard up against the stops.
SNR 99% :D
NeoPhyTe
1.3m Famaval dish
Inverto Black Ultra Quattro 0.2 - 28.2°E
_______________
80cm dish
Inverto Black Premium Quattro - 19.2°E -V/L
Invacom 0.3 Quattro - 13.0°E -V/H, H/L, H/H
_______________
Inverto Unicable Multiswitch IDLP-USS2OO
Albacete, Spain
72%snr here in south east of spain (at least it says my vu solo searching that freq manually) (searching it shows BBC RED Button Stream 4)
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
Lyngsat etc are listing the frequency as 11464 H. Super strong in Ireland, the full 20 dB on Dr HD Grand Triple.
BlindFaith
TBS 5925
Lyngsat etc are listing the frequency as 11464 H. .
Not only Lyngast et al. but also the NIT says 11464. Maybe the admin could change the title ;)
Fredrik M
Gibertini 125 dish, Inverto Black Ultra single aimed at 28.2 E, built in Philips TV receiver
Triax 110 aimed at Telstar 12 (15 W)
Landvetter (15 km E of Gothenburg), Sweden
The signal is very strong here in south western Sweden. Confirms previous observations that there is a correlation between frequency and signal strength for TP's on the UK beam: the higher the frequency, the stronger the signal. I almost wondered whether it was on a European beam rather than on a UK beam.
sonnetpete
wordpress.com
Normandy, France
Needless to say it's very strong here....though the VU+ is showing the frequency as 11461H
